Results 16 to 30 of 50
Thread: W58 7M-GTE clutch choice
    Default Re: W58 7M-GTE clutch choice
    Quote Originally Posted by Ryley
    is the 7mge flywheel a worthwhile upgrade? what's different from the 4m to 5m flywheel peewee?
    Just measured the 4m flywheel, it suits a 9" clutch.
    Not sure what size the 5m/7m ones are.
    Montrose
    A decent clutch place should be able to piece together a clutch kit to hold what you're asking there for not too much money. Personally I'm not a huge fan of the Exedy kits, I think they tend to be too pricey and not offer what they claim.
    I'm with shinny. Not so sure about these Exedy clutches. I think they're OK for a mild street driven vehicle....
    Before you part with your hard earned, chat to BGT in Hawthorn.
    Whatever you do, don't get a PBR clutch.
    I dont mind my Exedy clutches, i had a 3 puck in my GZE which operated beautifully, and the full face in the Sprinter is good too.
    wiltshire
    I had a 6puck ceramic in my n/a which was fine ,
    Do stay away from unsprung centreplates tho as there not suitable for everyday driving .
    BTW if your one of those people that like to depress the clutch before starting the car , dont do it with an uprated clutch as the extra pressure puts a high load on the crank thrust bearings (until oil is properly circulated) and can induce premature wear
    5M-E vs 7M-GE for anyone that cared
    225mm left, 240mm right
    240mm left, 225mm right
    CrUZida, is the 4M the same as the 5M?
    It would appear that the 4M flywheel would be similar to the 5M one.
    Hard to tell without putting them side by side.
    7M-GE and 2JZ-GE clutches are definitely interchangeable. The guys on the CelicaSupra forums are frequently using 2JZ clutches with their 7M upgrades.
    This is what I have been running on my 2JZGE, just with an uprated pressure plate.
    M through to 5M (and early 5MGE) run 225 mm clutch plates. Late 5MGE and 7MGE run 240mm clutch plates (I don't believe the 6MGE ever came in manual form from factory). 7MGTE runs a 244mm clutch plate.
    Not in the diner Alf! Conversion King RyleyMA61's Avatar
    this is excellent, thanks heaps guys.
    I'm going to head off to a clutch specialist very soon, I just need a flywheel. A 7M-GTE flywheel won't fit a W58 will it?
    Good to hear about the 2JZ-GE clutch too, How have you found your clutch GT?
    After spirited driving my thrust bearing likes to have a bit of a rattle when the clutch isn't depressed, so I may as well get a new one of them too.
    probably a question best for the clutch guys, but any rough ideas on what i should budget? $500 for upgraded PP, new clutch and thrust bearing a bit optimistic?
    cheers guys.
    wilbo- want to sell the 7mge flywheel?
    Ryley,
    My 1G is the smaller 9" setup, but I doubt it'd make much difference price wise. Mine was $420 for a 30% uprated pressure plate, a heavy duty clutch plate, a machined flywheel and a new thrust bearing pressed onto the holder...oh, and they painted it purple
    My ultimate power figure I suggested to them was around that mark, and I told them it would be driven hard, but won't be driven with no mechanical sympathy (flat shifting, burnouts). I said it'll probably see the drag strip a couple of times a year, and hopefully the circuit.
    That was an estimate, they went up in chunks from there, the next being a puck type, and the more pucks, the more expensive. Personally, I would either be going a heavy duty one, and if I was going the puck style, I wouldn't bother unless I can afford one of the better ones.
    I paid $500 for a brand new high-clamp pressure plate, 5-puck ceramic drive plate, throwout bearing and flywheel machining. That was a couple of years ago but the price should still be fairly close to that.
    Excellent, thanks guys. All I need to do is source teh flywheel and then I'll start going around to clutch places. If there are no good ones in Ballarat, I'll head down to Melbourne.
    No point in screwing around with shit that ain't no good.
    My final newbie question- The pressure plate is included with a clutch isn't it? Ie, I won't have to source a clutch to suit flywheel, then a PP to suit flywheel and clutch....
    Thanks heaps guys, most appreciated.
    They have been Exedy units and I keep bending drive straps, hence my less than enthusiastic response to the Exedy comments. That said, I think there is some other problem and probably not the fault of the clutch per se.
    When they work, they work really well.
    Nope, it is behind a 7mge atm...seems like a lot of work to take it out
    Oh and come on, someone give me some rep for the shit I posted already
  1. SC14 electromagnetic clutch
    By mic* in forum Tech and Conversions
    Last Post: 17-12-2005, 10:01 PM
  2. to 7m or 1jz
    By EMD-MX83 in forum Tech and Conversions
    Last Post: 29-11-2005, 10:56 AM
