gen3s the best has slightly more oomph.... larger injectors i think?
you can tell which gen 1g you have with the injector pluc colours, yellow, lime and green?
blake
Hey all,
wondering if any one could help, by tellin me what differs between each generation of 1g's which ones the easiest or best to modify any info is muchly appreciated.
Nathan
blake
The gen3's also are reported to run more advance on the ignition.
Gen3 1g-gte plugs are all grey, and the ECU plugs are not only grey, but differ a fair bit from the previous gens.
Hydra
JZA61 Celica XX
gen 1 = 7psi - Water to Air Cooled - Grey Injectors
gen 2 = 9psi - Air Cooled - Yellow injectors
gen 3 = 11 psi - Air Cooled - Fluro Green injectors
In regards to modding, Gen3 is the best of all they start with more power so therefore better to start with
Get ya Zorst done , Get a bigger frontmount cooler , Get a Boost controller, get a single turbo conversion to something semi-large , add 14PSI then do skids![]()
Gen1 has yellow injectors too. The 1GGE has the grey ones.
I recommend a Gen3, they're the newest and have the most go. They also have *slightly* larger turbos and a more advanced ECU.
The gen1/2 ECU's are made using straw and mud, and rely totally on chance to give the correct mix of fuel and ignition timing.
Gen3 turbos are nice, you can easily throw them on a gen1/2 engine with a little work - just get a dremel and a grinding bit. Works a treat!
Hydra
JZA61 Celica XX
I'm pretty sure there is a bit of spit in their tooOriginally Posted by Hydra
Seriously though, none of the 1G ECU's I've come across have been very good.
Bring on some form of aftermarket ECU then!
Hydra
JZA61 Celica XX
Engine Type Valv/Cyl Year Disp. BHP Torque Bore Stroke CR stock boost+other remarksG series (inline 6, belt, 2.0L, 1979-): Soarer, Celica Supra, Crown, Cressida, Altezza
1G-EU SOHC 2 79-82 1988* 125@5400 127@4400 75 75 8.8:1
1G-EU SOHC 2 83-86+ 1988* 130@5400 127@4400 75 75 9.2:1 EFI-D TCCS
1G-EU SOHC 2 86 1988 105@5400 116@4400 75 75 9.2:1
1G-FE DOHC 4 88- 1988* 135@5600 130@4400 75 75
1G-FE DOHC 4 98 1988* 140@5600 133@4400 75 75 9.6:1
1G-FE DOHC 4+VVT-i 98 1988 160@6200 148@4400 75 75 10.0:1 Altezza
1G-GEU DOHC 4 82-86+ 1988* 160@6400 133@5200 75 75 9.1:1 Crown + most others
1G-GE DOHC 4 82- 1988* 150@6200 134@5600 75 75 9.5:1
1G-GEU DOHC 4 86 1988* 140@6400 120@4600 75 75 9.1:1 Soarer, Supra
1G-GEU DOHC 4 85/86? 1988* 140@6200 127@4000 75 75 9.0:1 JP
1G-GZE DOHC 4 85- 1988* 168@6000 167@3600 75 75 8.0:1
1G-GZE DOHC 4 86 1988* 160@6000 152@3600 75 75 8.0:1
1G-GTEU DOHC 4 85/86? 1988* 185@6200 177@3200 75 75 8.5:1 air to air IC, JP
1G-GTEU DOHC 4 86 1988* 185@6200 173@3200 75 75 8.5:1 air/water intercooler
1G-GTE DOHC 4 85-90 1988* 210@6200 203@3800 75 75 8.5:1
its s'posed to be a table![]()
you can see the gen3 makes the most power from factory, 210hp
definately the best to start out with.
ive ran my stock gen3 on 16psi on occasions...seems to handle it well
by stock i mean all but a large IC and 2.5" mufflerless exhaust
hello
I'm running a gen2 w/ gen3 turbos at 15-17psi, seems OK, but the turbos are getting a little tired i think.
I dont blame them, they are often glowing bright after a good run at night.
Hydra
JZA61 Celica XX
thats interesting.
my plug leads on my 1GGTE tell a story of 1992..........unless they've been replaced at some stage. although in saying that my motor is immaculate inside.
Originally Posted by Grega
How do u know this?
which bit?
the leads have 1992 printed on them
my engine is immaculate inside - i know this from swapping the sump from mid to front type.
arent all enginesOriginally Posted by Grega
hello
only the ones that have been looked after....
