Page 1 of 9 123 ... LastLast
Results 1 to 15 of 122
Thread: Glazed Synchros from Redline Shockproof (R154)
    Default Glazed Synchros from Redline Shockproof (R154)
    My R154 was sent off to be rebuilt because it was being a real bitch to get into gears and i figured the synchros were gone.
    Called up today to find the box has been pulled down and is in 100% tip top condition, "almost like new", however the synchros have been glazed as a result of running redline lightweight shockproof gearoil.
    I was told to actually change to a blend of oils that i will confirm tomorrow, but apparently the redline (which is highly rated by many people) has 'over-lubricated' the synchros, causing no gear engagement.
    So here i am putting $120 of oil into the gearbox thinking its the best thing for it, and its actually not.
    Has anyone else had this experience and can someone actually explain whats happens to prevents the non engagement?
    I just don't understand how an oil can be too good.
    Default Re: Glazed Synchros from Redline Shockproof (R154)
    oil prevents friction... synchros need friction.... need a balance
    sucks the $$ oil may nto be right tho
    is the oil need to protect the gears or the bearings or the synchros?
    will changing to another for the synchros affect the rest of the box?
    so the solution is to mix the redline with something inferior?
    Crikey, that's interesting to know.
    I was thinking about Redline oil for the next gear change. Hmmm, I'll have to give it some thought now.
    Where's Toobs and his Royal Purple or whatever it is?
    seeyuzz
    river
    that kinda sucks "I'm sorry, you've used oil that's too good"
    lucky I need to spend $140/litre on v160 stuff
    Olde ****** Automotive Encyclopaedia ToDa30/4's Avatar
    south australia
    I believe some local scooby driving rally folks had the same problem. DAMN bad luck
    Project ST215W 300 AWKW Killerwagg'ss .staring in the garage .soon
    ST185R 385 AWKW now SOLD ..Daily '89 Eunos Roadster.
    Project '75 KE30 37.4 RwKw PIMPster. doing it for Angela RIP 1964 - 2011
    Meh, look on the bright side, you don't have to pay to have the 'box reco'd, plus you no longer need to spend $120 on gear oil!
    I must say that's the first I've ever heard of Redline oil not being the nizzles shizzle, chuck some regular old castrol VMX-80 in there & see how she go's. I also don't really understand how oil can be too good though.
    What about redline super lightweight gear oil? Although I don't suppose you wanna spend another $120 unless you're sure it's gonna work.
    S.A
    Quote Originally Posted by Draven
    $160 / litre ??????? Ohhhh yeah that must be that stuff that comes in a solid gold bottle and comes with its own little pixey that instals it for ya
    NOTHING IS CHEAP THESE DAYS !!
    On a serious note its the first i have herd of this too. Im using the heavy weight stuff in my w57 and havent had any probs yet.
    Black supra: What redline oil was it -- light weight / heavy weight etc.
    Have you viewed the syncros for your self to get an idea of what the glazing looks like?
    Bad luck for some.
    Until my box suffers from 'glazed synchros' ill continue to be amazed at how good this stuff is.
    p.s im on my 2nd year and 2nd gear oil change of RL LW SP GO and the box is still going strong, and gear changes still require a whole lot less effort compared to before the use of this product.
    JZA70|R / 12.45 @ 111 mph.
    Junior Member Grease Monkey Jasper's Avatar
    Redline MTL is the best thing for R154s
    According to Redline it's formulated to provide increased friction at the syncro interface.
    It fixed my R154 which was so bad on second gear that I almost rebuilt it.
    S.A
    black supra : maybe you just dont drive hard enough ! lol
    Pew Pew Pew! 1st year Apprentice poombah's Avatar
    Forrestfield
    i had mtl in my r154 gearbox when i first had it rebuilt, but 1st gear thrust washer shat itself after 5000kms so it went out and i ran cheap gear oil in (Castrol VMX 80), then the 4 and 5th chipped teeth so i had to get a new cluster fitted and AFTER that i put redline shockproof in and knock on wood its been good for almost a year now and ive done a track day, about 5 skidpan days and a sprint day... as well as a few mundaring 'togue' runs and a once down the drags.... shockproof is good.
    - Russ
    '80 kp60 starlet
    Quote Originally Posted by 30psi 4agte
    I was just about to say the same thing!
    Although I would have put it like this "Hey Glen, maybe you're just a pussy, and change gears like an economic girly man?!? "
    It's redline lightweight shockproof.
    Quote Originally Posted by BigWorm
    How's your auto cressida?
    I just need more straight road to get it on boost.
    No i havent.
    S.A
    ha hah ah ah ah love it!!
    i have thinking and maybe it is actually true to a certain degree.
    The redline oil is a performance gear oil and is designed to work in harsh conditions where excess load and fast shiffting is seen. If you were to drive easy on the box all / most of the time then maybe it will cause the syncros to glaze ???
    I dont know black supra ( glen ) so dont know his driving style but this could be a possible cause.
  1. r154 shifting experiences
    Last Post: 24-11-2009, 10:47 PM
