Results 1 to 11 of 11
Thread: T Belt Light
    Junior Member Grease Monkey off-road's Avatar
    NT
    Default T Belt Light
    Does any one know how to turn off the timing belt light
    on the dash of a HZJ78 Landcruiser?
    The 75 series had a button that you pushed with a pen but the 78's
    don't appear to have it.
    Default Re: T Belt Light
    take it in to toyota they may hav took reset it by comp
    Deal with the Frog Backyard Mechanic Cool1's Avatar
    Isnt it a combination of holding the trip button in then turning on the ignition. Or something similar?
    if u hav ur manual, check in their
    I think the Camry has a circuit breaker you have to reset.
    But as Selk said, the manual will know all.
    some cars u have to reset the speedo sort of
    theres a special button on the back of the cluster
    it resets the 100 000 km when the light comes on
    it doesnt reset the numbers on the front just something internally on the back
    Junior Member 1st year Apprentice tin can's Avatar
    Sideshow
    I have a lot of ppl ask about this at work and i asking the services dudes and thay told me take out the cluster and there will be a switch at the back of it.
    You have to move one lug to the other postion if u get what i mean
    ill check it tomorrow and ill post it up here for u
    thanks jess
    im not a Mechanic im a parts interperter
    current project: ke70 with 3tet
    now with 114kw on 10psi
    NT
    Thanks everyone.I' ve sorted it out.It is reset using the trip reset button.
    Quote Originally Posted by off-road
    What else did you have to do? Or do you just hold the button in for a period of time?
    NT
    Hold button down then turn ignition on.Hold down for another 10 seconds and release.Number 15 (for 150000) will appear. Press again and number will change to 1.
    Keep pressing until you get back to 15. Hold button in on 15 and after about 5 seconds
    speedo reading will re-appear in display and when you start car T-BELT light will be
    off.
    Ahh yeah, I was kinda right
  1. you can light up your speedo with LEDS
    By puzzle man in forum Tech and Conversions
    Last Post: 21-03-2006, 11:34 AM
  2. AE82 100kw motor Shift Light Install
    Last Post: 29-12-2005, 11:22 PM
  3. how to remove light rust on bores? pic included
    Last Post: 22-12-2005, 12:59 PM
