Check the wiring at the back is getting 12v with a multimeter (with the key turned to acc)
If it is then check the ground, if the ground's ok then the ciggy lighter socket itself is probably fubar
If there is no power then run a new wire to it, shouldn't be too hard, tap into an acc wire somewhere, put a fuse on it and a spade connector to attach to the ciggy lighter
