what car did it come from? the crown motor would be easiest since it had a separate ecu from the trans, but i think it's still possible to do it with others.
ps, i have a crown ecu if need be.
Hi all,
Nowe I know this question may have been asked a few times in the past but I'm in urgent need to get the wiring data in a simple format to hook wire up a 1UZFE engine to the standard ECU wbut will have a Supra 5-speed behind it, not the auto.
Any help would be great, thanks all.
beer me!
Came from a lexus fron cut
lexus what? sc400, or ls400? there are lots of variants of the 1uz
beer me!
My wrong...came from a Soarer UZZ30 Coupe
Resurrecting a dead thread here but do you still have the pin out diagram for your crown ecu? I have a 1uz from an LS400 with a crown ecu i'm trying to splice together. Need the pin out diagram for the ecu and a wiring diagram for the ls400 (I think i've found a wiring diagram but it was from an 'unknown' engine so a bit iffy on it)
Also was told that a 7m had a similiar plug to use to splice the two together, which i've found out to be wrong, anyone know what plug I can readily find to use? is a 40p plug.
If anyone can help, that'd be great.
40 pin plug would be from a ~93-98 model. 2JZ's in turbo and non turbo have the same plug.
What sort of crown ecu are you trying to use? A mid 90's thing?
DONT DO IT!!!!!!
Find a loom and ecu that is complete.
The savings in $$ is NOT worth the headache of trying to do what you are planning.
You're most likely right, but, you got to try these things atleast once.
Just need the pin-out diagram for the ECU and then I'll be able to see if it's do-able. If anyone can help, cheers.
I'll let you know if things go tits up, CrUZida, so you can say 'told ya so'.![]()
I'm in search for the subj.,too . Only could find a '90 aristo thing, but mine is from late-90's crown. Got the complete wiring, only need to power it properly.
What part number is the ECU and what is the pin configuration?
Will get to the car soon to check out the marking. The engine has no VVTi and no distributor either. ECU looks like 2JZ-GTE's one with 4 or 5 connectors, each having several rows of pins.
p/s The ECU is 89661-3A080, has 4 connectors: 34,22,16 and 28 pins
