Just going to quickly go over the installation process.
Take out the old LCA
Install the GH LCA into the crossmember
Guide the sway bar linkage into the hole on the LCA and pop the Jack under the very end of the LCA. You can see in this picture the ball joint does not have enough movement so the PS arm and the base of the strut cant sit flush with each other.
So all you need to do is, while holding the strut and PS arm in place jack up the jack slowly until the base of the strut and PS arm do sit flush.
And there you have it, they sit flush! If you do not do this and try and ‘pull’ them together using the bolts, you will strip threads. Install the Toe Rod into the LCA, which may require some elongating of the holes, depending on how good you are at marking and drilling. Then tighten everything up, the sway bar linkage, Toe Rod studs, strut to PS arm bolts, crossmember mount bolt. Please note it is recommended to do up suspension components, which have a bush, tightly while the car is sitting level on the ground. If you do not have a car hoist, hire a local midget like Yian to get under thereor by some car ramps.
Next problem is the stock tie rod ends are not long enough. The wheels in the picture are straight and the steering wheel centred. This shows exactly just how much they are short by. By my measurements I am short by 30mm. I have heard that you can use bluebird inner rack ends on AE86’s to rectify this but I did not investigate this route. The route I decided to take was to use RA40 Tie rod ends and Middle rods. Stock tie rod ends are 170mm long. So I needed the RA40 ones to be 200mm long.
This is a picture of the RA40 Tie rod end and middle rod. Sourcing those middle rods are hard though… AW11’s use the same middle rod on the rear tie rods and I reckon some other Toyota’s have them too. They are 170mm long.
This is the RA40 Tie rod end and middle rod together. Problem, they are 220mm in length, not the required 200mm. Solution? Take 10mm off each end of the middle rods.
Saw off 10mm off each side of the middle rod and file a notch out of the middle arm the same distance in as the stock notch is located for the locking bolt.
