G = performance head
One is from the is200, the other is an older motor i'm sure some of your are familliar with.
So my question is this: if going by the letter codes toyota uses for its motors, the only difference between the two is the top end of the motor. I'm not sure what the 2nd G in 1G-GE stands for, but i know the F in 1G-FE means the motor has an economy head!
Both 2L straight sixes - so what is interchangable between the motors, if anything? Perhaps headers?
Please exuse the question if it is silly, i know 1jz, 2jz, 3s, 4as, and 3m's but not 1gges! Someone teach me! haha
thanks team.
G means twin cams each driven by the cambelt and wide angle between the valves. F means narrow angle between valves [and therefore cams] and the exhaust is gear driven from the inlet cam. because the different valve angles the pistons are different.Originally Posted by ViPeR_NiPPleX
inlets are differnt as the 1G-FE has siamesed ports and the 1G-GE has individual runners.
Last edited by Rcubed; 13-11-2006 at 02:04 AM. Reason: spelled out that last statement refers to 1G-FE/1G-GE
1. There's no point arguing with an idiot. They'll just drag you down to their level and beat you with experience
2. Don't argue with an idiot; people watching may not be able to tell the difference
nice, let me chimein and ask , are any of the belts? or other maintance items such as water pumps and thermos interchangable?
jason
i'm pretty sure that fan belts are the same due to same arrangement on the block. timing belt is not as single cam drive for F dual for G. i'll check parts manual re the water pump and thermos.Originally Posted by US1GGTE
From what i've seen, the water pumps are similar. To use the 1G-FE water pump you need to grind down one of the ribs on the top side, otherwise it will foul the plastic timing belt shround.
Hydra
JZA61 Celica XX
the pumps carry the different part numbers, but appears to be similar
Part_Numbers
the pump gasket is unique for the 1G-GE / 1G-GTE but this can be substituted on the 1G-FE.
Ah nice, pics!
The top left rib (while looking front on at the pulley) from the 1G-FE pump needs to be "modified" with a grinder![]()
Mine has been working fine for ages like this![]()
Hydra
JZA61 Celica XX
siamesed ports? like... 3 ports?
don't they both have 6 for intake and exhaust?
or the f has 6 and the G has 12?
The Blocks are the same, the front plates are slightly different, the rear plates are the same, if the 1G-GE is a late one the crank is the same, but the rods and pistons are not.
oil pumps and housing is the same, the is200 water pump will fit, but the cam belt cover from the GE will not mate up to it snugly... the thermostat setup is different too.
Some kind of BMW
'97 Hilux Surf SSR-X LTD
..::VVTi 1UZ-FE::..
Originally Posted by oldcorollas
yep the G has 12 inlet runners [in 3 groups of 4]
but, like the F, 6 exhaust
yeah, but thats just a TVIS manifold - nothing to do with the F vs G as a general statementOriginally Posted by ta23-mbzq-nnr
F vs G is just valve angle/cam separation, and the cam drive configuration
G certainly doesnt imply 'performance' anymore either. things are trending back towards narrower valve anges these days at the high end of the motorsport spectrum.
ed
../delete/ban
tech moderator
no T-VIS on mine!Originally Posted by ed_jza80
its still not a generalisable statement F vs G
../delete/ban
tech moderator
you are correct especially as the 1G-FE had at least 13 years more development. the 1G-GE ceased production in the early '90sOriginally Posted by ed_jza80
