had similar symptoms on the 7MGTE when it ripped open a vac line.
Eldar.O.
Ive spent a while looking around but cant find any real info on what i need so iam posting up here
my sisters cressida is playing up atm, and we have no idea what is going wrong
problems:
while coming home the other day it started to stall while driving ?.... it would drop in the revs and then burst back again........and we had it idling, and it does it...... revs normally, then sort of dies....but gathers it before it can stall........
did the diagnostic and it threw up the water temp sensor......so replaced that, but it's still giving that same code ??
and every now and then when we start it, it runs like it's on 5cyl..... runs rough, idles goes up 2000rpm and drops to 800, then back up........then down.......it's really weird
it sounds like it's an electrical problem.... but we have no idea, have checked all the wires and hoses, cleaned out the ISCV and some intake lines.... replaced leads as thought they were the problem.....
we have done all that we know, if anyone could enlighten me, please........as it might have to go to MR toyota to get fixed if we cant find the prob
Rob
- 1997 Toyota Aristo 3.0V - JZS147 - 19" Work VS-KF's, Garson VIP exhaust, Tein CS coilovers, Mines Ecu, Saber Gauges.......Greddy FMIC kit soon to come
Eldar.O.
you might need to reset the ECU, the code is stored even after the problem is fixed. Reset the ECU then check for the code.Originally Posted by rob_85
TPS has moved?
also try resetting the ISCV
../delete/ban
tech moderator
how do i reset the ISCV ??Originally Posted by ed_jza80
reset the ecu before, but will give it a go again![]()
Rob
start engine, run, disconnect ISCV...
kill engine, pull main efi fuse 20mins, reconnect ISCV...
replace fuse, restart engine, idle, kill engine
you should hear the ISCV winding in and out resetting itself
see here:
http://www.autoshop101.com/forms/h26.pdf
ed
../delete/ban
tech moderator
Try unplugging things to eliminate them from the loop. I've had the same thing happen from another 7mge. In the end I couldn't figure out what fixed it. I changed ISCV and unplugged then reconnected the TPS and it came fine!
will give it a go tomorrow![]()
Rob
*cough* bhg *cough* *cough*
water temperature sensor? that's a really weird one... erm.. are u sure it's running on 5 cylinders? after the leads it could be the coil pack.. but yea do the suggestions above..
good luck with it.. and post back what's happened![]()
mine sounded like it was runnning on 5 cyl, it was just the high tension cables, not sure if yours is the same thing though
Current - 2006 Colt Ralliart 100.2FWKW@6000rpm,
Past - 1988 Toyota Camry V6 (Sold) (VZV21) 117kw@5600rpm, 1994 Lancer Station Wagon Executive (sold) (86kW+@6000rpm), 1986 Corona S (sold) (73kW@4800rpm), 1990 Cressida GLX (BHG) (142kw@5600rpm)
ive just done my BHG on my 1ggte.......so i know what that sounds like
it's not that......because some times it runs fine, except for the stalling.....
where as my 1g ran like utter poo ...... what happens when coolant is floating around![]()
Rob
dude if your still having probs i'l try and come see ya. Unless the car is drivable and you wanna bring it round here maybe?
Bust me an sms yo.
Matty
cant drive it .......properly .......keeps cutting out....Originally Posted by Wildsupra
my olds said he would pay ya to come out and lend your expert hands![]()
Rob
yeah man my labour is way cheaper than mr toyota's.
I'l be in touch yo.
Maybe later tonight if i get my crown painted
Matty
thanks for coming around matty
still no luck guys..... ISCV was reset and ecu was set.........still no worky
possibly be the Coil pack ?
Rob
