TE72/T18
there are some differences between the way the old and new style of T50.
there should be pictures from Toycrash somewhere on here i think
can be done, btu a spacer/fiddling is needed
was just doing a search when i saw that 3t engines came out with t50 22 spline gearboxes? is this true and will i be able to bolt my bellhousing on it to fit my 4agte? What cars to the 3t engines come out in????
TE72/T18
is the tailshaft diffrent on the t 50 from them cars, the article said that the 3t tail shaft was 22 spline like the t50 that are 83 and up. I may be wrong
well.... from my very vague memory, a KE70 and KE30 tailshaft went into both TE72 and AE86 gearboxes, so i would guess (until someone corrects my poor memory) that they are same...
i thought (more vaguely) that the input shafts differed on the different T50's??
"from THOSE cars"
anything celica and t50 is a 20 spline anything later than the ta23 ('75-6) had 22 spline, i had posted this information in one of your many threads where you could find the answer by searching, the same applys here search and you shall find
stu: the k series gearbox has a smaller splines /centre shaft, but same size outter bit, the ke30 shaft will fit and seal but because the splines are smaller it wont work
no imput shafts dont vary (hence my early t50 fitting snugly into a 20c clutch)
oh... so what freekin boxes were my tailshafts from then KE10/30/70 fit into two different T50's for sure.....
i'm totally confused now
thanks
well thats what i have read, ill see if i can find where i found it, also wouldnt a k50 have different splines? i call a visit to the wreckers....
is the yok of a k50 a 20 spline and will it fit a 20 spline t50?
thats probably it....
Originally Posted by skiddz
Wrong!
TA2x, and TE7x are all 20 spline output shafts.
AE71 and AE86 are 22 spline output shafts.
As for placing a T series bellhousing on an A series gearbox ie a T bell on a 22 spline box) - there are minor difference in the front bearing support. yes you can physically bolt the bell up, but the lack of support to the front bearings needs to be addreessed with custom made shims - not cheap to do properly, but required to prolong the life of the gearbox.
Originally Posted by Peter Costello
i stand corrected, i thought the te7x 's were 22 spline.... guess not
My failing memory, tells me that the T18 5 speed box, had a missing spline on the output shaft ie. a keyway. The tailshafts were the poo, as the universal joints were non replaceable.
cheers Chuck.
MS51Crown Coupe,
