Results 1 to 8 of 8
Thread: refinishing a steel tray
    Default refinishing a steel tray
    hi all
    i have a tray back to suit my new 81 Hilux.
    it is made out of steel rhs/box section tube
    with a checkerplate floor
    it is currently painted black
    but the paint is all scuffed up and there is some moderate rust bubbling the paint off in some places.
    the rust is crusty in some places but not affecting the structure yet
    how is the best way to remove the existing paint (sand, sandblast, stripper, etc)
    clean the rust back to clean metal (sand, converter, acid)
    and refinish the thing? (powdercoat, paint acrylic/2pac)
    want it to be affordable, i have access to 12cfm and acrylic gun.
    if going 2pac i would need to get it sprayed etc. professionally
    Default Re: refinishing a steel tray
    Do you want to use it as a ute or some sort of mini truck?
    If you want to use it as a ute, I'd give it a quick wire brush, then have a look at the POR-15 range of metal finishes..
    ute
    needs to be presentable and durable but not show smooth.
    Rosewood
    marine carpet? and wire brush the rest?
    Toymods Club Member #302 Backyard Mechanic hi-ace's Avatar
    Get it all bead blasted. When I did my Hi-ace up, it needed it. And the guy primed it so it was ready to paint.
    Then paint it, and it'll be right for a long time.
    If it feels good "DO IT" Unless it harms others.(or upsets the RTA)
    Enjoy what you have To Day,cause you can't take it with you.
    My old Hi-Ace
    vic
    you could buy a new tray of me LOL, or do what we do here when a referb is needed, wire brush the floor and use a orbital sander to get any bubbled rust of the Side and rear coamings. Coat the floor with a nice thick anti slip paint, (it has rubber in it) and paint the side and rear coamings to the colour of your chocie
    Quote Originally Posted by hi-ace
    how much did this cost?
    You'll have to check in your local area, but it only cost me about $100.
    You know, a friend of a friend.
    My old Hi-Ace
  1. W5X Speedo Drive Comparision (Steel plate vs Alloy plate)
    Last Post: 12-08-2011, 08:58 PM
  2. help needed on CT26 Identication, Ceramic or Steel
    Last Post: 04-01-2007, 06:33 PM
  3. Hilux from flat tray to ute bed?
    By floody in forum Tech and Conversions
    Last Post: 10-09-2006, 02:31 PM
  4. Steel tapers
    Last Post: 10-07-2006, 12:02 AM
