I've only got one problem with your guide so far......
When you go to remove the factory strut from the car, it is actually a VERY GOOD IDEA to loosen (not completely undo) the nut in the middle of the strut top when the car is resting on the ground.
I've found on a number of occasions that the bastard strut top nut simply wont farken undo with the strut out of the car, especially if you have non-captive springs. You try to undo it, but the shock arm just spins with your attempts to undo it![]()
This is the point where you abuse Mr Toyoda for using nylon lock nuts over the next 2 hours whilst you bolt the struts back in....
It's about 100000% easier to undo those nuts when the weight of the car is resting on the suspension (ie car on the ground)
