Results 1 to 4 of 4
Thread: Removing old paint from rubber door seals
    Default Removing old paint from rubber door seals
    Hi guys, what is the BEST method of removing paint from door seals, the result of a very poor spray job.
    How slack are some people, either remove the seal, or tape the bloody thing up. How hard is that?
    Previously, I have removed the seals, and scrubbed with thinners, and cloth. On the thicker bits of paint, I have used steel wool, and even wet and dry paper. When cleaned, I have sprayed the seals with satin vinyl spray.
    Does anyone have a a better way.
    If this has been covered before, my apologies. Search found nothing.
    cheers Chuck.
    MS51Crown Coupe,
    Default Re: Removing old paint from rubber door seals
    vinyl spray will be a bitch to remove - that shit soaks into plastic and rubbers....
    Suggest the remove and work it with thinners/metho/something method.
    soak in brake fluid? provided it doesn't damage the rubber...
    i did the thinners wiping on the windows to deal with overspray - my partner gently wiped on the thinners and i wiped off moments later. We covered everything with towels to prevent collatoral damage.
    I think you want to avoid paint solvents on window/door rubbers or treat them straight afterwards to minimise chemical damage.
    you can also remove paint with white spirits or dry cleaning fluid - but its also a solvent (hydrocarbon) so the above point still applies. I used it to clean overspray off trim.
  1. Guide: Removing paint from plastic parts (more input needed)
    Last Post: 13-04-2006, 02:09 PM
  2. Rubber mounted windscreen installation - without the heartache
    By o_man_ra23 in forum Tech and Conversions
    Last Post: 17-01-2006, 11:55 AM
  3. Removing Sticky Rubber (under door/bump strips)
    By toaster in forum Tech and Conversions
    Last Post: 17-11-2005, 11:56 AM
