I picked up another two sets of brake pads that still had plenty of meat on them.
Brake Pads
The MA70 caliper takes a DB413 brake pad. These can be found on the Supra Turbo MA71 (April 1989 - 1993), Soarer (1985 - 1988), and 1985 - 1988 Cressida GLXi, GLi and MX73.
The three sets of brake pads I got were made by Bendix (DB413), Firepower (FDB413) and Protex (DB413P). Here they are side by side:
The Bendix pads did not have the backing plate and anti squeal plate that the Protex and Firepower pads had. Also the Bendix catalog shows the only pad without a central groove as Ultimates, but I'm unable to confirm this at this point in time.
The shoes may need replacing as they look fairly worn:
My plan is to take the shoes, plates, rotors and calipers and sandblast them clean, give the backing plates a coat or two of gloss black, the rotors' non-contact surfaces some gold paint and the calipers painted with Septone Brake Caliper paint (either red or blue). I've organised for the backing plates and rotors to be machined on their inner circle diameter too. Then its off to have the rotors skimmed lightly to true up the surface.
I didn't pick up any Hiace axle bearing studs as I plan on using high tensile cap screws to hold everything together.
That's it for now. The sandblasting should be done some time next week.
