Yes it has two wastegate actuators. Just use a T piece to join them both and connect to the boost controller.
well just bought a manual boost controller and wondering if the twin turbo steup has 2 wastegate actuators if so how do i setup the boost contoller
Past Cars: Blue TA22 2T, Green TA22 2TGEU, Orange RA28 18R, Green RA28 18R, Multicoloured RA28 18R, White JZZ20 Soarer 1JZ
Present: Maroon GA70 Supra, FMIC, Adjustable Cams, SAFC II.......
KE70- Stock as a rock.
Norbie!
www.norbie.net
so use t-piece to join line coming from the boost controller to both wastegate actuators?
Yes.
You can T the boost reference from the turbos, or use one and block the other.
And T the wastegate actuator lines into the output from the boost controller.
Go Johal's diagrams![]()
Has he run a 12 yetOriginally Posted by JustCallMeOrlando
If in doubt power out
I drive past his car every day... Maybe I should put a note on his windscreen "Have you run that 12 yet? Love Toymods"
Doo it and post a pic on hereOriginally Posted by boris
Dude please post pics of your setup during installation and once installed as I will be doing this very shortly and don't want to fuck it up.Originally Posted by chrisrundell69
What sort of boost controller did you get? I hope it's not a bleed valve? I'm going to try out one of the turbotech ball bearing valve controllers off ebay as they seem to be all the rage at the moment and for less than $40 you can't go wrong!
turbotech is good...just dont let bigworm fuck with it
Project Soarer II - Sold
Evo 5 - The silver fruitbox
Fuck off, so I'm good enough to install it, but can't adjust it???Originally Posted by MR 1JZ
It's not my fault your crappy 2J is crappy....
Care to elaborate boys? I've read that they can be very sensitive to adjust? Did you find that it brought boost on faster?
Yes very sensitive to adjust, & yes boost does come on quicker. It seems though that best results are achieved with bigger adjustments, ie. trying to get only a couple of psi increase is very hard to do, whereas a good 5-6psi is much easier. FCD for great success.
by "fuck with it" i meantOriginally Posted by BigWorm
"ill just stretch the spring a little...its an old tuners trick"
Bah, not my fault you only wanted to increase boost by a gnats dick!
While tuning my Jaycar DFA on the dyno boost suddenly started wavering up & down a few pounds, & this was fixed by stretching the spring in the boost controller. Prolly not necessary if you're too scared that too much boost will cause you to lose control of bowel function.![]()
