There's been a few threads about the wonderful side-draught Solex carbs that make the superlative 2T-G and 18R-G engines run so well.
So, with no further ado, let me post the following extracts that will not only show you all the bits of these carbs, but also how to tune them.
There are 19 images, which I will make thumbnails, so it will go over 2 posts, due to the10 image limit per post. I set the image size to 1024x768 (for 17-inch screens) to make them a little bigger and easier to read.
Also, this is for tuning the Solex on your 2T-G. The 18R-G is very similar, and I have this info, but I will need to scan it and convert to JPG and host it before I can post. So, in the meantime, here's the 2T-G stuff.....
seeyuzz
river
ill add that a VERY useful tool for tuning 18RGs is a infared heat gun. i havent read the above articles yet but i doubt these were around 10 years ago. we use these since 99% of bikes are multi carb'ed. you point them at each header to compare temps.
also if you can somehow get 4 small vacuum tubes into each port close to the engine then a motorbike shop will be able to check the balance with one of these. something dodgey i have seen is 4 holes drilled in the bakelite spacer with 4 brass tubes pushed in.
this is exactly the type of one we have at our motorbike shop
hello
Once again nice work River.
Regards
Rodger
River I love you!! You have no idea how long I have been waiting to see a thread like this!!! Where was it when I was trying to tune my solex's over 9 months ago huh??![]()
Awesome stuff, this is why your rep is so high! Thanks![]()
Toyota Car Club (Qld)
Did I not send you the 2T-G manual on a CD?
It's in there!!! I bet you didn't even bother to look.![]()
Crikey, I oughta bitch slap your rep!![]()
seeyuzz
river
I had a look through the cd but im sure it wasnt there.....Maybe I missed it
I'll have another look tonight... I was going to print the lot out and put them in plastic sleeves, its just one of those things I havent got around to I guess.... Besides, the silly has been running pretty good since I got it dyno tuned, and Ive hardly had to touch the thing since
GW River,
Pulled the goods again matey.
Any change we can see one of these threads for webbers?
Can base tune my 42 dcoe's on the 4age but thats as far as my knowledge extends!
once again river nice work<on knees pray to the almighty
and last night i bought the same PDF off ebaynot quite the same but very similar
Pictures not working anymore![]()
I just came upon this thread too & No pic's, if its wasn't for peoples responses I would have thought it was a send up on the Good Old Solex's ..
I just found all of the photo's in this album.
http://s357.photobucket.com/user/GEO...?sort=3&page=1
Save these in soft copy, print them out and bind them together for a workshop manual.
http://www.mikunipower.com/PHH01.htm
