i'd strongly suggest making it solid (ie no flexible joint between flange plate and bar) as this will give you the most stiffening effect possible. fo a custom built brace adjustment is not necassary.
the way i would fabricate it is like this:
bolt the plates on to strut tops, cut the bar to size and sit it in place.
tack weld the bar to the plate in a few places (i know your paint is nice so you would probably want to cover it)
unbolt and carefully remove the bar, fully weld it, adding bracing if you think it will help. If you can jig it up, do so, as this will reduce distortion.
trial fit to the car, might need some adjustment with the tapometer to fit. when it fits nice, take it off and paint it, then put it back on.
Personally i would use round mild steel tubing, with a moderate wall thickness as it is cheap and will weld to your end plates with ease. 4mm plate seems about right for the plates, possibly a tad on the thick side, but it wont make much difference.
is it possible to triangulate against the firewall at all? might be worth looking in to.
hope this helps
