Need the complete setup from a 20+ R series engine, ie 20 (USA only) 21R 22R.
Complete setup from a manual RA60, bellhousing, clutch ass. etc
Hey people,
My w50 sitting behind the 18r-c in my RA28 lost 5th and is deteriorated elsewhere so its gotta come out.
Now Ive got a w55 sitting at a mates place waiting to go behind a 3tgte once its ready but im hoping that all i have to do is swap the bell housing as th 55 has a T series bellhousing and the w50 has an R series one. From memory they are exactly the same but I would just like to confirm it.
Can anyone verify this?
RAI
Time to revive the 28.
Originally Posted by skiddz
Your kidding!
Just to clarify the 55 is going behind the 18r as a temporary fix till the 3tgte is ready and aren't the w series boxes externally identical. But if not can you tell me why?
thnx
RAI
the w55 is all alloy case, the w50 is all cast steel case. w50, w55, w57 are all the same ratios basically, its only the w58 which differs - longer overdrive.
w52 out of hilux has shorter gearing.
THE OFFICIAL TOYMODS BOGAN
MA61 - sunroof., 7MGTE, 4.11 lsd, w58
MA61 - Built 2JZ, 9" diff, big brakes -1st car + the toy
LN167 - dual cab fourbie, gu patrol chassis + suspension/ driveline, built 1.5jz
and the bolt pattern for the bellhousings to the box are different also.
The W50 has a square style bolt pattern and the W55-58 has an upside down horseshoe shape.Hope this clarifies a few things for you.
Cheers Brett.
thats interesting, in which case the w52 looks identical to a w50, (cast iron etc) so id assume its the same pattern?
Thanks Guys,
I guess its off to the wreakers a-hunting bits i go, I'll just have to tighten the belt and do it.
Means less money to spend on the rebuild of the 3tgte which is what i was hoping to avoid
Thanx
RAI
why not just get another W50? or a W40? if it's only temporary i wouldn't go blowing money on it.![]()
beer me!
ill have a w58 very soon if youre interested....Originally Posted by RAIncarnated
Thats the plan!! I know where i might get one too, unfortunately it will get spent out of my seat and x-member fund.Originally Posted by joecoolmk2
Im almost tempted to take it as a sign and pull it off the road and ramp up my engine swap.
If you're upgrading to a 3T you'll need to do a transmission swap anyway as there are no bellhousings to mate a W50 to a T block. The alloy-case W5x boxes are much nicer anyway.
Norbie!
www.norbie.net
Yes there is! Just probably never imported to Australia.If you're upgrading to a 3T you'll need to do a transmission swap anyway as there are no bellhousings to mate a W50 to a T block.![]()
I have several of these. I use one of these to mate 1G and P51.
here
Originally Posted by Jayem
Very interesting.Whats the chances of aquiring one of these bellhousings?
Cheers Brett.
3T/13T Coronas and Cressidas came with W50.
Hi, anyone know where to get one of these bellhousings?
It'd be nice to mate my w50 to my 1GGTE?
"If you keep fixing it for long enough, eventually it WILL break."
- RA28 3TGTE - I sold it. Bad idea. www.glisten.net.au/celica/index.htm
- RA23 3TGTE - 168rwkw 12.9sec Toffee Apple [URL="http://www.toymods.org.au/forums/threads/26625-RA23-3TGTE-168rwkw-12-9sec-Toffee-Apple?p=561925#post561925[/URL]
