You will need a better FPR, with the correct fuel pressure those injectors should be good for a safe 650hp (engine). I would get them cleaned and flowed if you haven't already.
You won't make anything like 29psi reliably without a full standalone ECU. Even if you did the result would be sub par and reliability/driveability would certainly be questionable.
You would need some type of funky fuel, there's no way you can safely & reliably run anything above 1.5bar on conventional pump fuel. I'm not saying it can't be done but with standard internals you have no safety margin for even the lightest knocking at those boost levels.
Honestly there is no need to run 2 bar. Your best bet is to run a conservative amount of boost on a well sized turbocharger. If you choose the right turbo you can make at 18psi on pump fuel what another turbo might make at 25psi with C16.
