Results 1 to 7 of 7
Thread: where have u mounted your filter relocation kit in your MX83
    Default where have u mounted your filter relocation kit in your MX83
    i have just bought a summit relocation kit, i was just wondering where u guys have mounted the oil filter
    I have the battery still in the engine bay so thats not an option
    The boobs are back
    Rosewood
    Default Re: where have u mounted your filter relocation kit in your MX83
    mount it where ever it'll fit, does it really matter?
    mounted so you dont dump oil everywhere when removing the filter?
    for ease of access I would think the glove box would be a beauty of a spot
    Seen them behind the passenger strut tower.
    Why not relocate the battery as it is cheap, easy, better to have weight at the back and then you have a spot for your oil filter
    QUICKEST 1JZ'S IN OZ
    Not just a regular Backyard Mechanic ProjectSleeper's Avatar
    Washer bottle is behind the strut tower on the pax side, so you will need to relocate that..
    You can mount it low beside the engine like I think Ribfeast did, - I mean, sure, it's not as easy to get too than if it was on the top, but you can make it easier than stock, and you need to crawl underneath anyway to remove the sump plug,,,
    I chose to relocate the battery..
    i'm gonna mount it under the rh headlight, heaps of room, plus since i wanna run a cooler later on it wont be out of the way
    The boobs are back
    I mounted it next to the sump. It is only zip tied though as there is nothing to bolt to. Stuck some strong hard drive magnets to it to attract metal particles.
    244rwkw / 328hp @ 18psi
  1. Oil Filter Relocation
    By Starfire in forum Tech and Conversions
    Last Post: 24-05-2007, 07:40 PM
  2. Oil Filter Interchangability
    By 3sgte in forum Tech and Conversions
    Last Post: 14-03-2006, 12:35 AM
  3. Full flow Oil filter relocation line thickness
    Last Post: 02-01-2006, 06:21 PM
