Results 1 to 11 of 11
Thread: Starter motor solenoid, how to put it back together?
    Default Starter motor solenoid, how to put it back together?
    Hey all, lets just assume I pulled apart my starter motor solenoid and want to put it back together
    How would one go about getting the bushes to sit in, so you can slide the center back in? The bushes are pushed out by springs.
    Joel
    1996 FZJ80 Landcruiser.
    Email : [email protected]
    Default Re: Starter motor solenoid, how to put it back together?
    You talking about how you can re-insert the armature, so the brushes can run against the commutator?
    seeyuzz
    river
    Yes, I think that is what im trying to do
    The brushes have sprung out into the center though, so makes it impossible to slide the armature (assuming thats right word for what we talking about here) in.
    do the brushes come out the back? a few DC motors i have seen work like this, you put the armature in, then put the brushes in their slots, followed by teh springs, followed by the clips that hold the sprongs in place.
    have a look at it and try to work out how they put it together at the factory.
    Junior Member Backyard Mechanic ndgcpr's Avatar
    there is 2 brushes right? i think i usually stuff something like a small screwdrive to hold them back, but i must admit, it isn't a one man job
    Noisy Diff and Gearbox Club of Pine Rivers
    and you thought your car was loud
    The Soarer brought to you by the letter TT
    There is 4 in this one!
    The back does kinda come off, but it always remains attached by wire that runs up to the magnets in the housing. So cant get it off far enough.
    Can you take some pics? I'm sure our collective brains can get this figured out. I thought that there were soem countersunk screw that, when unscrewed, allowed you to pull out the springs and the bushes.
    PM the Witzl, 'cos I've lent him some of my repair manuals and he maybe able to check the page for starter motor shit and tell you what the go is.
    seeyuzz
    river
    Tallahassee, FL USofA
    starter - brushes contact the commutator of the armature.
    solenoid - just a heavy duty switch, and may also do some mechanical work, like moving the starters drive gear to the flywheel.
    on most, push the brush up into its holder/guide and then pull the spring off the top of the brush to push on its side & hold it in place. before the end plate is fully in position, just push down on the brush and the spring will snap back into place. a little tool/hook out of a coat hanger may help.
    old ladies probably put'em together in 15 seconds on the assembly line.
    Hey all, here is a picture of it .. This might make it easier to explain
    Joel
    Isn't there 4 reset (countersunk) screws on the outside of the body above each of the 4 brushes? There should be a spring under each of the screws that provides the force to keep the brush in contact. So, if there is a screw, be careful when you remove it 'cos the spring will want to jump out. Then the brush should fall out. Remember the brush postion so you can put it back into the same hole and same direction so it fits around the commutator.
    seeyuzz
    river
    Hey all, thanks for info everyone.. Its all good now.
    Hey River, close mate, there was 2 screws right at the end of the base, once those were removed the plate holding the brushes slide out. I was then able to slide the centre bit back in while holding the brushes apart. Then put the covers back over it all
    Woohoo my car starts now.
    Joel
  1. 3K starter pinion center distance from crank center?
    By 510rob in forum Tech and Conversions
    Last Post: 14-01-2006, 09:34 PM
  2. 4AGE 16 valve reduction starter
    By parrot in forum Tech and Conversions
    Last Post: 10-01-2006, 09:36 AM
  3. Tips on replacing the starter motor in an RA65
    By azmodai in forum Tech and Conversions
    Last Post: 22-12-2005, 06:12 PM
  4. 20v starter motor
    By Selk in forum Tech and Conversions
    Last Post: 19-12-2005, 09:08 PM
