Results 1 to 8 of 8
Thread: Ra28 specs??
    Default Ra28 specs??
    Hey all, Im after the standard specs on a stock ra28 LT2000, such as dimensions,weight, standard power output,brake specs, ect. Any info would be good as its for my engineer.
    Thanks
    Default Re: Ra28 specs??
    Brakes: poo (power assisted, solid single piston front discs, drum rear)
    Standard power output: poo (around 86BHp at the flywheel)
    Weight, around 1050-1100kgs
    Dimensions: not real big
    Search around the forums, there is info on all of the specs you have asked for.
    Oh, standard diff is a 6.7" centre 4.1:1 ratio two pinion open wheel centre.
    RA28 was available with both 13*5" and 14*5.5" rims with 4*114.3mm PCD and around a +20 offset
    PS, if your going to butcher an RA28 for dorifto or other motorsport use, make sure it is rusty or bent or both... we cant afford to have minters die on race tracks as they are getting too hard to find for the enthusiasts.
    Junior Member 1st year Apprentice MeanMachineRA28's Avatar
    Jan 2007
    Aw Man, you beat me to it Owen...looks like you covered most of it anyway.
    Overall Dimensions are:
    1600mm Wide, 4215mm Long and 1280mm high.
    2425mm between front and rear wheels
    Hope this helps.
    Nathan.
    Oh I thought diff ratio was 3.9:1 for manual and 4.11:1 for auto
    RA28 Turbo 18RG
    RT104 - spare toy
    BF II XR8
    Nope, you will have a T292 diff... like all RA28s (auto or manual) and its a 4.1:1 (not 4.11)
    Forum Member 1st year Apprentice Jimmy's Avatar
    Feb 2007
    Thanks for the help guys much appreciated!!! And dont worry i wont be hacking it up
    Im not too worried about you hacking it... more worried about you crashing it.
