Or for for the lazy ones out there, (i.e - me), MX-73 discs and callipers go straight onto ST-141 hubs.Originally Posted by Norbie
Checked and confirmed today... RT142 corona fuel tank and fuel filter fit into RA60 perfectly... The RA60 even has the mounting bolt holes for the filter on the side of the engine bay. The fuel line from the RT142 wasnt very close to the right bend though, so it took a lot of re-bending to get it in, but i got there. Ill let you all know how i go with other parts of the swap, like the clutch pedal etc.
This is the same for KE20/25 Corolla'sOriginally Posted by BradW
Some more info on KE20/25
KE20 and KE25 doors are different - windows surround is lower on the 25 due to lower roof line but can be changed with a KE20 surround if fitting on a '20
KE10 thru to KE26 stud pattern on wheels is 4 x 110 - interchangable with early 70's Mazda
KE30-55 discs can be fitted to KE20 hubs to keep stud pattern, but minimum 13" wheels required with KE30-55 discs
ROB
jsut trying to confirm wat is said here. T50 rubber gearbox mount onto a K50 gearbox crossmember?Originally Posted by 74ROLLA
T50 gearbox rubber mount onto K gearbox crossmember.Originally Posted by Dom-KE55
Is there a difference between K40 and K50 gearbox crossmembers?
Stewart would be able to answer this.
Brad
Old Corollas never die...
My KE30
Dude,Originally Posted by tricky
TA22 and RA23 hinges are not interchangable. They are different sizes. Sure you might be able to make them work by bolting onto a different spot but they DON'T fit straight on.
Try bolting an RA23 hinge onto a TA22 in the original place and you will change your view on this....
BTW, an auto tailshaft from an early TA22 will fit straight onto a W55-57 gearbox without any mods. Also an auto cross member is a perfect fit for a W55 into TA22, just have to move the mounts back a little.
Simon
K40 and K50 gearbox are identical in every way (length, shifter position, etc) so same crossmember.Originally Posted by BradW
EXCEPT FOR K50 OUT OF A KE70, which is a different shifter position
ROB
Another one for those doing a smallport (100kw) 4age conversion.
I bought an ecu and engine harness for my conversion and found that the harness did not come with the 12 pin ecu plug (which I believe is connected to the body harness on the donor car). After much searching I found that the wide body Camry (sorry, don't know the chassis code) with the s series engine has the same type of plugs on the ecu as the 100kw 4AGE.
I was also told by The Witzl to look for an abs plug from a toyota of the same year model as the donor car as these are also the same.
Brad
My KE30
another one for the AE86/70/71 TE72 boys
Tercel 17mm rear sway bar is a direct bolt on
Hi all,
Does anyone know if it is very easy to get the 4 spot front brake calipers off the 4WD Hilux and bolt them onto the front of the 2WD Hilux?
Thanks
The rear main oil seal for a 4E engined Startlet fits the 1G motor perfectly.
I need confirmation on this but im about 99% sure....
AW11 Proportioning valve can be fitted to AE86 that has T series disk rear end to fix the bias issues created by replacing the drum diff....
Adam
Yello and black AE86 J-blood obesity kit - Built 4AGE
Blue X70 Cresta 1GGte
Originally Posted by AE25
I have a YM35 Liteace, i was under the impression that the gearbox my car uses bolts directly up to an s series engine, i.e. 3SGTE etc.
So K series liteaces have bellhousings for W and G series engines, and the Y series Liteaces have bellhousings for an S series engines, good for that RWD 3sgte conversionthey're also very tough boxes aswell (apparantly).
Eldar.O.
Its W and G series boxes that are same bolt pattern, not engines. So what you need to confirm is if the Y engine and S engine are the same or similar bellhousing pattern. If they are then the Y to G bellhousing will work on an S to W.Originally Posted by EldarO
Callum
Yeah, that is correct. Joel at one point, and Gabe too, were using 1Y bellhousings on their 3S RWD projects.
