Results 1 to 15 of 20
Thread: Brake options for hilux diff?
    sa
    Default Brake options for hilux diff?
    Hi all. I am wondering what brakes you have fitted to a hilux diff?
    I would like to run 4x114.3 stud pattern, but it would also be nice if i could fit 13" rims over them.
    Has anyone fitted a smaller drum? e.g. early corolla, liteace or something thats not as massive as the standard hilux drums?
    What about r31 disc brakes, is 14" the smallest rim you'd fit over them?
    WTB: EARLY KE20 PARTS AND N.O.S
    Default Re: Brake options for hilux diff?
    Not a direct answer - but this is a great read and may provide some pointers:
    http://www.toymods.net/forums/showthread.php?t=18913
    Youngy, that upgrade will give 5*114.3 stud, and I dont think 13" rims will fit over them (I think 14s would struggle, they are pretty massive)
    Rotorace... The brake package will need to be suited to what you want to do with the car. What front brakes do you have?? What are you using the car for?? If its just something like drag racing, then braking isnt important (have 400m to stop) so you should be able to modify some RA40 drums (will fit in 4*114.3 13" rims), just need to check the distance from the axle face to the side of the housing. This will require custom fitting though.
    If you are going for track type use or daily driving, go for larger rims, they will improve handling by lowering the profile of tyres required. Then the MA70 brakes Youngy pointed out could be used (need to re-drill) and you can use bigger brakes on the front too.
    sa
    Cheers fellas.
    Ok, so the car will be mainly street, i would like to run it t the drags too.Thats where the
    13" rims come in.
    But having said that, theres no drag strip in SA, so i'd like to chuck a lap or two at malalla...
    Dont want much do i
    I figure ill set it up for street at this stage, then if a particular fom of motorsport takes my fancy i'll modify it to suit.
    The car (ke20) is fitted with 266mm (i think) magna rotors and just early commo calipers.
    Now what do you guys reckon?
    Everything im talking about is a compromise of some sort, so maybe i'll have to compromise:
    stud pattern? i could run 4x110.
    Wheel choice? r31 rear brakes, 14" rims min.
    Brake performance? fit drum brakes of a usable size.
    I don't know what to do. I'd just fit drums, but it seems silly to do more work to fit drums..
    I did have a look at fitting the ke20 drums, but the hilux has a large semi-floating bearing hub assembly which would make it difficult.
    Thanks
    On the street the best safety feature you can have is good brakes. So you will need to look at how powerful your brakes are at the front, and match the rears. The little magna rotors with commo callipers will probably be quite well matched to Celica sized drums, or RT142 avante rear disks. But I dont know how easy they will be to match to the Hilux diff.
    What engine/power and torque output do you have that requires the heavy hilux diff?? Why cant you put a smaller F series diff in?? Or even a T series if you have a K series motor??
    I have just recently made up some simple caliper brackets to fit Nissan R31 skyline calipers to a hilux G-series diff. Keeping the disks 4 stud im using rt142 avante disks. I found this to be the easiest and simpliest way to go about converting to disks. The R31 calipers double as a handbrake as well so the only other mod needed is a custom handbrake cable.
    be warned, disk handbrakes are renowned for sticking. The RT142 drum handbrake is a much better setup. If those disks fit over, then it would be a good setup for you to match the front brakes you have. Just make sure you have a master cylinder that will do disk rear brakes.
    tried fitting the both live axle and IRS rt142 rear corona brakes to G-series diff. IRS setup is very sililar to the popular MA70 upgrade but the backing plate is just too small to machine out to suit the large G-series bearing carrier. Same sort to story with the Live axle brakes which are the same as commodore setup except the corona ones use an alloy backing plate. You need a 20mm spacer to suit between the backing plate and the bearing retainer but you still run into issues with the handbrake lever fouling to the large g-series bearing retainer.
    Junior Member Grease Monkey Cruiser97_80's Avatar
    Tasmania
    Don't know whether this will help you or not but i have heard of ppl fitting older subaru front callipers to the rear of 4x4 hilux's. The main reasoning to have a useable hanbrake. 4x4 hilux drum brakes won't work after they have been in mud and water.
    1990 ST185 GT4 3SGTE
    1991 ST184 SX 3SGTE
    1991 SW20 GT 3SGTE
    1998 ST215 GTT 3SGTE
    2008 VDJ200 Sahara
    sa
    The car will be powered by a rotary.
    I didnt really want to use something with an internal handbrake drum because it makes the outside diameter of the rotor huge. I am trying for a small as possible basically.
    I was thinking along the lines of pubes idea as the rotors are smallish and the caliper is also your handbrake.
    Thanks
    Dont say you werent warned.
    Junior Member Domestic Engineer MRMOPARMAN's Avatar
    vic
    if the calipers are in good nick or rebuilt, there wont be a problem with them sticking. its only when they get old, and never get lubed/ brake fluid flushed is when they start to give problems.
    i agree with guys that said try to setup a system with internal drum handbrakes, they do seem to work better, however they make the conversion a little harder. even with the larger diameter of the drum type rotor, that shouldnt cause clearance problems with rims. your main concern is the inner diameter/offet of the wheels, and the outer edge of the braske caliper.
    as for drums, they can take a bit of work + more maintenance, but they CAN be made to work quite well in mild circuit applications. hilux rear drums in my own experience have been quite good!
    Quote Originally Posted by MRMOPARMAN
    I suppose it was Foulcan items I was working on. But lets face it, we all get slack sometimes and some things get missed.
    The rear calipers from the r31 im pretty sure are girlock items. They are basically the same as all rear brakes used on comodores, falcons, toyotas but the r31 model has the addition of the integrual handbrake.
    sa
    Hey pube, is there any chance that i could sneak r31 brakes under 13's?
    By The Witzl in forum FAQ
  2. T series rear end diff centre change guide (warning, pics!)
    Last Post: 31-05-2007, 12:57 AM
