Results 1 to 15 of 15
Thread: Belt run diagram for 4AGZE
    Nurses rock! Grease Monkey lunar_c's Avatar
    Feb 2007
    Default Belt run diagram for 4AGZE
    Has anyone got a diagram (from a manual or anything) of the belt runs on the 4AGZE? Would appreciate the help!
    Ben
    Victoria, Mt Macedon
    Default Re: Belt run diagram for 4AGZE
    The belts should be pretty simple. There are 2, both 5pk, and going clockwise around the belt from the crank pulley you'll see:
    On the back belt (closest to block) - crank pulley, tensioner, SC, water pump, crank pulley again.
    On the front belt it'll be - crank, tensioner, power steering AC, alternator, crank. Though the power steering pump is often removed if used in a conversion.
    Also I think some AW11 motors came without power steering, and had the alternator above the aircon.
    So essentially the back belt drives everything on the intake side of the motor, and the front belt drives everything on the exhaust side.
    Hen
    Feb 2007
    Thankyou! Have some rep ..
    Much appreciated!
    Regards,
    Ben
    there are three belts (on the AE101 GZE at least).... the two ones of the crank are 5PK belts, and the one from the a/c compressor to teh P/S pump is a 4PK if memory serves rightly (might be a 3PK tho...)
    Feb 2007
    Thanks dude .. I bow to your MS paint skillz..
    That dude with the AE95's Backyard Mechanic Kebin's Avatar
    Constitution Hill, NSW
    And here is the part numbers for them
    Witzl - Are you sure the RHS tensioner goes there? I'm sure mine's on top (AE92). Does it change betwen generations?
    Hen
    This is the layout on my ae101 motor.
    The power steering pump mounts above the air con compresssor on the rhs.
    Feb 2007
    Thanks for all the help guys! Rep for part numbers Kebin..
    Just finished cleaning and organising all the bits and pieces .. got the head back together. Had to make a few gaskets (just had to grab a big port top end set) but should be all set to throw it back together now..
    By the way Kebin I hope you changed that rear mount in the pic ! Centres fallen out.. oops!
    Quote Originally Posted by lunar_c
    Of course i did
    ummm... thats actually the CV shaft braket
    yeah i got the A/c and alternator belt tensioner in the wrong spot..... so my memory aint that great.
    Hahaha o yeh well my other mounts were stuffed anyway
    o yeh witzl thanks for the rep.... smartass!
    Feb 2007
    It is too .. guess I've seen too many broken engine mounts lately.. Hehe!
    Junior Member Backyard Mechanic benjamin's Avatar
    be careful with the sc and water pump belt length as if you have a later model gze (with the smaller sc pulley) it will be shorter than a early model (bigport) one.
    Feb 2007
    Cheers guys,
    Sorted all the belts out and put the bottom end back together last night ..
    Big props to madrolla68 ..
  1. Replies: 47
    Last Post: 23-10-2020, 08:38 PM
  2. squeeling noise from timing belt -4AGE- ITS BACK! :(
    By WHITCHY in forum Tech and Conversions
    Last Post: 13-01-2008, 07:42 PM
  3. 4agze timing belt 1 tooth advanced
    Last Post: 31-03-2007, 08:58 AM
  4. 1GGTE power steering belt
    Last Post: 13-09-2006, 07:20 PM
  5. 4agze supercharger belt prob??
    By 4AGZE_rolla in forum Tech and Conversions
    Last Post: 02-07-2006, 04:50 AM
