Results 1 to 15 of 15
Thread: What has a PCD of 5x112mm
    Act
    Default What has a PCD of 5x112mm
    Hi
    Just looking for a spare tyre for a trailer I have borrowed and its 5x112 just wonder what cars came with this so I know what to look at at the wreckers
    Stitt
    Default Re: What has a PCD of 5x112mm
    Mercedes Benz.
    Act
    anything esay to find I.e Aussie cars???
    Perfectionist & Grease Monkey Tony's Avatar
    I don't think there are any. Audis & some Volkswagens have 5 x 112 also. Must be a German thing...
    ST185 GT4 Group A Rallye No. 29 (sold)
    Renault Clio Sport 182 Cup
    Quote Originally Posted by TheStitt
    Hi
    Stitt
    Early GMH eg. Torana or maybe Volvo.
    Have a look here or even here, that suggests Audi and Mercedes, as GT suggested.
    Now that would be a flash trailer with the three pointed star wheels
    Peter
    victoria
    not really relevant, but with a large enough persuader you can use a mercedes wheel on a magna, no fun taking it off though (got me home)
    Act
    Well I found out after a trip with a sample wheel around Pickies. It was indeed early holden HT and HK and later volvo, the ones that look like bricks.
    It wont be 110mm, coz they didn't change to metric until the Commodore (5x120mm)
    Pre-commodore was 5x4.75" (5x120.7mm)
    I'm not sure what pre-pre-commodore was though.
    Just found a site that said HT was ~107.99mm, or 4.25"
    yeah early torana i heard was 108? matches some volvo or something???
    Black Betty >HERE!<
    (\__/)
    Tasmania
    HK-T-G and Volvo ran the same stud pattern in a 14" and EJ-H,HD-HR and Torana ran the same but in a 13" Rim.Early Commonhores ran the same stud pattern as HQ-HZ except 4CYL Commo which was the same as Torana.
    Cheers Brett.
    So when did Commodore change from 5x120.7 to 5x120?
    HT Holden and Volvo are 108 x 5.
    Mercedes definately 112 x 5. Yep, if you are a complete retard you could put a Merc wheel on a Ford/Toyota Magna, especially if you are happy to have a couple of broken studs and a wheel come flying off at speed. From memory however, I think the central hole in the Merc wheel is wrong such that it's impossible to put on the front of either a Ford or a Crown - can't remember - was a long time ago.
    Junior Member Grease Monkey rob20v's Avatar
    The post from Tony was right the only ones I can find are Mercs, some Audi's and some Volkswagen Passat's had them. Type 5x112 PCD into Google and they all come up. I just can't remember but I am sure there are some earlier model vehicles which use them.
    If it gets too hard and expensive do what I did and just change the trailer hubs to something more common as a set of hubs are only about $50 from most trailer places.
    As you have just borrowed the trailer you probably won't want to do this.
  1. Replies: 8
    Last Post: 13-01-2010, 11:04 PM
