Results 1 to 12 of 12
Thread: Durafix weld rods...anyone used them?
    Junior Member 1st year Apprentice ArJay's Avatar
    Default Durafix weld rods...anyone used them?
    Hey folks.
    Yer as the title says, anyone used Durafix fluxless aluminium welding rods? Looks pretty schnazzy in the demo but do they actually work?
    http://durafix.com/index.html
    http://www.durafix.com.au/index.php?...=technical.htm
    Rory
    Keep it Low and Slow
    AusZoku
    Default Re: Durafix weld rods...anyone used them?
    I have a DHC 2000 ozy welded thats meant to be able to weld aluminium with normal rods, yet to give it a go though
    Montrose
    Very briefly had a go, wasn't hugely impressed myself, although I've been told they can be alright.
    Cheers guys...
    Hmm...I'm guessing that under extreme temps this stuff would return to a liquid state?
    Hey Sam I checked out that DHC 2000 torch...looks awesome. Have you used it much? Any good?
    R
    AusZoku
    victoria
    Ive used em, and its ok for thin aluminium(you can weld a coke can) but i couldnt get decent penetration with em.i only used them once so you could probally get a better result than i got if you had some practice. that said i do a lot of arc/oxy/mig work and i found them hard to use. there also pretty expensive.
    Quote Originally Posted by ArJay
    Cheers guys...
    R
    can be quite good for steel, but I havent tried it on aluminium yet. Its very hard to get a neat looking weld. Worth $650 or something stupid like that and if it doesnt weld aluminium for me its going back whatever he says.
    Quote Originally Posted by celicapain
    Aren't they a brazing/soldering rod? There's no way you'd be able to get any penetration unless you ground a weld channel before hand...
    Thanks Sam.
    Do you think it'd be a worthy/cheaper alternative to a MIG/TIG? Easyish to use?
    Rory
    AusZoku
    There are a lot of times when brazing/soldering is better than welding, the opposite is also true. I wouldn't want to try using these rods for say cooler piping, but they could be a good thing for repairing castings.
    Junior Member Grease Monkey Bored?'s Avatar
    Yeah, as has been stated these are really just a solder that will work with aluminium. That's a useful thing to have in some cases, but to call it welding is a bit misleading.
    Occasionally you find that there is a need to solder aluminium for electrical stuff (eg. aluminium battery tabs) , and it's practically impossible without having the correct solder. OTOH some of the stuff you see people do with it can be a little disturbing.
    By the way, durafix is just one brand, and like most people pushing snake oil, they claim it's a unique product. In fact, it's a really common and readily available product - just google it.
    I've used a few sticks of a similar thing. Pretty fkn useless IMO. I'll just stick to the standard flux and rod myself
    Malicious
    Thanks for the replies guys. Pretty much explains it...cheers for the insight.
    Rory
    AusZoku
