Results 1 to 6 of 6
Thread: 7m engine torque specs
    Junior Member Grease Monkey Bored?'s Avatar
    Default 7m engine torque specs
    I have a 7m is in a billion pieces on the floor, and will need to be put back together in the next few days.
    Can anyone tell me what the torque specs are for rod bolts, main bolts and cam shafts?
    Any other official torque specs needed when rebuilding a 7m would be good too. (Head related stuff is documented well enough, but other info is hard to find amongst it).
    wa
    Default Re: 7m engine torque specs
    Cylinder Head Cover (Nm) 18
    Camshaft Bearing Caps (Nm) 20
    Cylinder Head (Nm) 78 (7)
    Inlet Manifold (Nm) 18
    Exhaust Manifold (Nm) 39
    Con-rod Bearings (Nm) 64
    Main Bearings (Nm) 102
    Pressure Plate to Flywheel (Nm) 19
    Flywheel to Crankshaft (Nm) 74
    Flexiplate to Crankshaft (Auto.) (Nm) 74
    (7) means in 3 even steps
    Excellent work. Thanks.
    7mge 7m-ge 7m, p00 motor, head torque, bolt torque settings, ratings, rates.
    oregon
    Western Aus
    80 ft/lbs for the head bolts, they love a bit of extra torque.
    Elmo.
  1. Toyota R Engine History
  2. MA70 --> JZA70 Conversion
