Page 1 of 3 123 LastLast
Results 1 to 15 of 34
Thread: 4AGE:20V head on a 16V block possible?
    NL-34-SH Grease Monkey unleashed__'s Avatar
    May 2007
    Default 4AGE:20V head on a 16V block possible?
    As the title says I want to put the 20 valve head on a 16 valve 100kw block.. is this possible? I've searched everywhere and can't seem to find any relevant info on this. I've read that you need a VVT pulley to run the VVT? I've also read that the piston clearance to the valves is not big enough and it might not run well is this true?
    It's because I need to do a head gasket on my car and I can't afford a 20 valve so I thought this would be the cheapest way to get one. Also what else would I need to do? New ECU etc..?
    I have an AE92 Seca SX
    thanks any help appreciated
    opinions are like a** holes.. everyone has one but thinks everybody elses stinks
    Default Re: 4AGE:20V head on a 16V block possible?
    Is it just me or is the SEARCH tab near impossible to find?
    its not a cheap way to do it,
    thats all the help from me
    Miss matiching heads and blocks is NOT going to be cheaper.
    16v pistons will not work with 20 valves.
    GameOn Backyard Mechanic Poggy's Avatar
    Yes you will need a VVT pulley, unless you just run normal adjustable cam gears, you can run a smallport ECU but wont run anywhere near as good as a 20v ecu, you will need to do wiring etc, for the effort it isnt worth it, spend the money on some quads and cams for your smallport.
    May 2007
    Quote Originally Posted by merc-blue
    well i did use the search bar and it did not give me the answers that i wanted
    you can mix and match dude but for minimal gains, it would probly be cheaper dropping in a 20v then pulling apart the 16v and mix and matching parts.
    May 2007
    Quote Originally Posted by Poggy
    i thought u would just need a 20v head and ecu for the conversion.. because i can get a 20v head for cheap..
    didnt know u had to pull the whole block apart
    Quote Originally Posted by unleashed__
    then you need all the intake such as quads etc plus you need the wiring for the sensors that go with the head.
    May 2007
    yeah i know.. the 20 valve head that i can get comes with all manifolds and sensors.. just no ecu.. so would i need a 20 valve ecu to run it?
    Yes otherwise it will run shit
    May 2007
    oh ok then..
    so thats all i need? or do i need VVT pulley aswell?
    oh ok then..
    doesnt the head come with a vvt pulley?
    May 2007
    guess so.. its jsut that i thought pulleys were on the block?
    but the 20 valve head i can get.. it is complete with everything
    No the VVT pulley is on the intake camshaft
    May 2007
    ok then.. well so i can just get the head and ecu.. plug and play and i'm done?
  1. TG engine info!
    By MitchE in forum Tech and Conversions
    Last Post: 30-07-2010, 07:27 PM
  2. 2TG head onto 3TC block...need help
    By quikestsilva in forum Tech and Conversions
    Last Post: 15-05-2007, 09:07 PM
  3. 2tgue & 3tgtue info
    By chippa07 in forum Tech and Conversions
    Last Post: 06-01-2007, 08:29 PM
  4. Matching your head to your o-ringed block.
    By PHOBIA in forum Tech and Conversions
    Last Post: 09-05-2006, 03:14 PM
