Top end torque??? If you are looking to extend the torque range then you want to avoid a long duration camshaft. The longer duration camshafts build plenty of power(hp), but tend to sacrifice a wide power band to get those type of #s. Here is what I did when it came to big port porting....
Porting on a TVIS 4AGE is a ticklish job... it is VERY easy to royally #$@%$& things UP! The keys to porting a TVIS 4AGE is improving velocity! There are two key areas to do this.
The first is about 40mm behind the valves in the intake port. The 4AGE head was cast in two parts the casting comes together at this transition point where horizontal flow transitions to vertical flow. Each port is a bit over cast and a Dremel with a meduim drum works well here. ONLY blend the ports... DO NOT enlarge them... you just want the flaw do to casting to disappear, so remove ONLY the minimalist amount of material to make the port blend from above the flaw to below the flaw. BTW... you can't really see this flaw... but you can feel it with your finger tips!!!
The second area that needs attention are all the intake joints. It is bad enough that intake ports are so large that they do not flow well originally, but because of so many joints, these joints also add many eddy points. So each joint also needs to be blended. Now to do this there is a problem... there are no alignment pins, or dowels from the intake, to the TVIS plate. There ARE dowels between the TVIS plate and the head. So I added alignment pins(roll pins) to lock the intake to the TVIS. NOW the ports can be blended together... remember be a minimalist!
Web makes a nice cam, they call their 294 grind, I've been using it for 8 years now, it pulls/makes power to about 7000 rpm("about" = give or take 100rpm). Stock cams usually run out of breath at 6600. Other cams that work well with stock fuel system parts would be HKS 256 or 264 cams. The 256 top out at about 7000, the 264 at about 7200. There are quite a few 272 type camshafts too, they top out at about 7500. Problem is 7500 is where the oem ECU has the redline and in some cases you might not make peak power before the ECU cut out.What cams do you suggest for increased top end torque, while still retaining factory computer, injectors, driveabiltiy etc.
Also stock injectors may mean you'll run lean. I'm running 20% larger injectors with my Web cams, you might want to look into a mild injector upgrade, just make sure you run the correct ohm injectors.
As for the rebuild.... check it all... but 4AGEs are pretty tough little engines I've seen disassembled 4AGEs with over 150k miles still showing cross hatching on the cylinder walls... with good valves and guides.
Valve springs will be needed if you run lifts in excess of 8.2mm(or there about) The Web cams have a lift of 8.18mm, I checked my springs for bind and although close... they DIDN'T bind with the 8.18mm Web 294 cams. There are some articles out there that say OEM spring bind occurs near 8mm.** OEM springs can be reused *IF* they are inspected using the FSM. New springs are usually between $120-$160 per set.
** -http://www.club4ag.com/faq%20and%20t...haft_story.htmThe stock valve springs should not only be replaced, but also upgraded to ensure that the valves can follow the new and sometimes more radical cam lobe profile. The stock valve springs are only capable of ».318” (< 8.0mm) lift. With the stock installation height of 1.366” (34.7mm), they bind at 1.048” (26.6mm) compression and they will float some where above 8,000rpm.
