For that sort of thickness id just do it my self.
Get a sheet of 300 grit sand paper place the sand paper on a piece of glass ( something flat) and rub the pad down .5mm
To take .5mm off this way will be a piece of cakeand will still be square.
Were trying to get some brembo calipers for our racecar, and they come in two varieties. For 5mm and 4mm thick discs. Our rotors have been designed as 5mm, and theyre already so small that i dont want to go down to 4mm. But theres a back order on the 5mm calipers, and the supplier can get us 4mm at a very discounted price.
so... is it possible to grind down each pad 0.5mm so we can run 5mm discs? The 4mm caliper actually has a +- 0.5mm tolerance on the disc thickness, so really would only have to grind down each pad 0.25mm. If it is possible, anywhere in SA thatd be willing to do so? theyre sintered pads btw, not your normal critters.
no more aw11
mx73 and brap brap time now
Or if you wanted to be really fancy you could pull the pistons out and take .5mm off of the top of them.
Don't forget to breath in the dust coming off the pat its grate for the lungs
reputation is nothing knowledge is everything
RA23 1GGTE 12.3@110mph
1980 RA40 now getting a 1G with new picsLOOK
Don't argue with an IDIOT.He will bring you down to his level and then beat you with experience!
grind it wet, should keep the dust on the paper and glass, and out of your lungs.
Elmo.
lol hahaha yeah especially back in the days of aspestos brake pads, oo yeahOriginally Posted by SIKTOY
it's sintered bronze, should taste nicealmost like macca's chips
beer me!
step out side, rub it on any piece of concrete....
of if you have a bench grinder, and the pads will sit on the SIDE of the grinding face....this way only takes 0.2 seconds
5mm DISCS? these for a bike or something?
to take that much pad material off, I'd use the side of a grinder wheel, nice and quick.
Wollongong Sporting Car Club - Secretary
Current Cars:
2004 TW Magna VR-X AWD w/6G74 - Tow Car
1989 AW11 MR2 w/4A-GE 20V - Track Car
bike or kart etc i reckon
beer me!
yep, do that, it'll do just fine
I use a surface grinder to do mine
Jealousy is a curse
Id stick with the dong it by hand. It takse longer but you will find that you can grind the pad down alot more evenly.
Originally Posted by IN 05 NT
formula saeOriginally Posted by joecoolmk2
no more aw11
Is spacing the calliper apart 1mm not an option?
