I got a good idea . . . dont bother!
hi guys,
ive been toying with the idea of putting a dash out of a later model hilux (98-02) into my hilux (84-88).
anyone heard of anyone doing this? and how hard it was?
or anyone got any better ideas?
rollsy
thanks for the in put mate! helps alot!![]()
yeah mate . . . no worries!![]()
Jordan, this is the tech section, try to keep the smart ass comments out of it.
if you think he shouldnt bother, at least say why.
Elmo.
YN 57, right? These sort of things can be done, it's just a matter of how determined and patient you are. It's not going to be a bolt-up proposition, and it won't be quick.
I've seen late model commodore dashes wedged into old (late 1960's) holden utes, so anything's possible.
I'd start simple with a tape measure over your ute and the intended donor, just to see if it will be a 'more-or-less' type of fit or a major cut-and-shut job.
Good luck and have fun![]()
'93 MX83 Cressy with 1JZGTE (now with engineered goodness)
'85 YN57 Hilux SR5 with 3.8l V6
'98 ES300 (with gold bits!!)
+ A Corolla and some non-Toyotas
i attempted a 00 into my 92, and it wasn't easy get it in & the end decided not to run with it.
It fouls in a lot of areas eg, around the cluster. Plus you have to trim the window side to match the different profile in the firewalls, then you have make new mount to line up the screw holes. But if wanna give it crack it is possible with a lot of work.
This guy put an AE92 Corolla dash into his '85 Hilux. But I gather he wasn't aiming for a stock look as he was using an aftermarket instrument cluster.
How good a fabricator are you? Could be fun![]()
Originally Posted by BabyZ
thanks for that mate!
hrmm could be interesting..![]()
something more eye catching would be good tho if im gunna go real custom..
will see wat i can find!
rollsy
Sorry O great one . . . hanging my head in shameOriginally Posted by EldarO
