Results 1 to 6 of 6
Thread: V band clamp leaking on exhaust
    Junior Member Grease Monkey Mr Multivalve's Avatar
    Default V band clamp leaking on exhaust
    Has anyone had a V band clamp leaking problem.
    Mine seems to have developed a small leak, apart from retightening it is there a recommended sealant, sealer that can be used?
    I did it up pretty tight when i set it up, is it something that needs to be retightened every so often? I did not want to go to gung ho and break it by overtightening it.
    Corona Creed:
    Good to Drink, Great to Drive, keep them separate to stay Alive!
    Default Re: V band clamp leaking on exhaust
    When you torque up a V band clamp, tigten up the nut then give the clamp a tap with a hammer the whole way around the clamp. This will make ture the clamp is seated properly. Then re torque and you should be done. Also, is the nut a locking type?
    I will have to check that, thanks for the info.
    Corona Creed:
    Forum Sponsor Conversion King
    from experienc ive found that most v bands leak to some degree.
    if they are thick machined items they wont leak much but the thin strap style ones have a bad habit of leaking and you have to tighten them every 5000ks
    if your exhaust runs a flex they wont be to bad but if not they seem to work the bands loose by flexing the sides of them, in short run a flex if you dont already have 1.
    if you have a wastgate pipe running into the dump make sure it has a flex on it as the expansion and contraction between the two will work a v band loose also.
    linden
    S.A
    I agree with that!
    In my experience also ... all the v band clamps i have used have leaked alittle. The v band clamp was designed for quick and easy removal /assembly of components. It is widely used in racing where a slight leak from the exhaust isnt of major concern or noticed.
    All i can suggest to you is to make sure your seating surfaces are true. Depending on the type you can check them with a flat file.
    I must be lucky.
    My Scorp has a factory sigma turbo setup on it. There is a v band clamp between the turbo and dump pipe, and the manifold and wastegate. No flexible joints anywhere.
    I put it all together with Loctite high temp copper silicon sealant and no leaks from the clamps. It's been like it for 6 months/17000k's.
  1. Unequal camshaft duration 4AGE
    By toddw in forum Tech and Conversions
    Last Post: 01-02-2017, 08:04 AM
  2. aw11 clutch master cyl leaking (again)
    By adamaw11 in forum Tech and Conversions
    Last Post: 05-02-2007, 10:48 PM
  3. 18RG/EU Exhaust Manifold / Flange Plates
    By Spectre in forum Tech and Conversions
    Last Post: 25-11-2006, 01:28 PM
  4. Hunting a particular SW20 exhaust
    By Lonewolf in forum Tech and Conversions
    Last Post: 04-05-2006, 02:33 AM
  5. 4AGZE Intercooler and exhaust suggestions?
    By DavisJD in forum Tech and Conversions
    Last Post: 07-02-2006, 06:20 PM
