as far as i know you cannt legally run a full roll cage in NSW on the street. the rear half can be welded in but must be covered with padding and also engineered, so if you wanted to run a fullcage on the track you would have to make the front section removable.
for cams the cage has to be made of mild steel as they no longer allow alloy cages.
what type of racing are you doing? unless you are entering the car into a CAMS affilated event ie IPRA events you dont need to comply with CAMS regulations because only events like IPRA events are you required to adhere to their guidelines.
