that all looks right, when the two dimples on the dizzy are lined up what i do is mark a spot on the rotor button and then on the housing to make it easier to make sure its properly lined up once its in.
then you will need to set the timing with a timing light. id suspect you simply havent set the timing correct using a light once the dizzy is in the rihgt spot.. remember to short out T1E1 when your setting the timing.
