.8mm sound about right if im running about 12psi?
just needa know what the plugs need to be gapped at for stock 1jz guys from jza70 supra cheers guys
Past Cars: Blue TA22 2T, Green TA22 2TGEU, Orange RA28 18R, Green RA28 18R, Multicoloured RA28 18R, White JZZ20 Soarer 1JZ
Present: Maroon GA70 Supra, FMIC, Adjustable Cams, SAFC II.......
KE70- Stock as a rock.
Yep, .8 is factory spec. I still run that at 20psi with no worries, some recommend .7 at high boost theough..
just get ngk bkr6e's they are already gapped to .8
cheers guys, putting em back in now hopefully they'll solve my not starting problem![]()
platinums are generally considered a bit of a waste of money on a modded turbo car... better off with coppers and swap them frequently
Yep if you're running higher than stock boost coppers are the go, platinums tend to foul too easily.
Norbie!
www.norbie.net
plus a full set of coppers cost the same as 1 platinum![]()
Originally Posted by Draven
yea mate i know they were in my car when i got the engine tho![]()
ALthough Ive had no issues running Iridiums gapped to 0.75mm at up[ to 20psi so far for 8,000kms...
11.72 @ 116.7mph = Quickest Stock Turbo Jzz30 series SoarerAnd 1st into the 11's
WOOOT!!!
Still going good![]()
Never had any issues with my platinums fouling. I run 0.75-0.8mm gap at 18-20psi.
244rwkw / 328hp @ 18psi
yeah but if you foul them and subsequently fuck them youre gonna be rather pissed aye...Originally Posted by Ribfeast
Project Soarer II - Sold
Evo 5 - The silver fruitbox
Probably more to the point is, why is it not starting and what have you changed? Sounds like they could be fouled already?
all fixed dw massive air leak from stock blow off valve + old black plugs, clean em up and removed blow off valve all good now![]()
Those stock 1JZ BOVs are a bastard, mine would leak all the way up until around 1-2 PSI and eventually seal. Made it a lot slower at building boost.
I ran a piece of hose from the stock BOV's output into the cabin for a laugh once, and went for a drive while watching the boost gauge, you could see it struggling to build boost, and feel air rushing through the BOV's output, before eventually sealing up. When I backed off the throttle it blew the hose clear out of the cabin onto the road lol
Plugged off the stock BOV location and fitted a Turbosmart Dual Port BOV near the throttle body and it has improved things quite a bit.
