Results 1 to 14 of 14
Thread: Rotary Engine Conversion - Corolla
    Default Rotary Engine Conversion - Corolla
    Hi, i have searched however it turned up nothing on 13B turbo engine conversions.
    Has anybody on this forum performed this engine conversion (13B into KE70/TE70) or will i be a pioneer?
    Potential obstacles i forsee:
    1. RX7s have steering racks in front of the engine Cross Member
    2. The trans tunnel in my Corolla may not be big enough.
    3. My T series may not hold 180 rwkw (jokes)
    Thanks
    Andy
    Go drifting...
    AGE-16V Automotive Encyclopaedia Dimmy's Avatar
    Default Re: Rotary Engine Conversion - Corolla
    a guy on the old forums did a rotary (can't remember if it was 12 or 13b) into an ae86. Unfortunately the car didn't last too long
    May want to search there
    I have been pruned by old man river!!!!!
    New Zealand
    Very common in NZ, have a look through the Rotahavik forum. Will need to google it, haven't got address handy.
    Callum
    also try searching for ausrotary in google, they have a lot of info there!
    check you canget it legal... it is not legal in NSW (2.5x weight for turbo), but it may be ok in the banana state
    LOL ^^ banana state!
    this badboy is going to be track use only and therefore legality is the last of my concerns.
    cheers guys, i will check out those sites!
    wish me luck
    Go drifting...
    Check out the ausrotary forums as well, rotary Corollas have been around for years so I'm sure you'll find some info there.
    Junior Member Grease Monkey 4SFED's Avatar
    Jan 2007
    I may be able to help you out a little bit - i have one in my TA22. I know its not a Ke70 but i am sure alot of my pains will hold true in any car...
    4SFED Celica
    13B Turbo
    www.4sfed.com.au
    The Supreme Backyard Mechanic
    RE the ae86 with 13bt in it from the old forums.....
    Engine was mounted using a 12a timing cover. That will allow you to mount the engine right at the face. A simple bar across the rails and some rubber isolators was all that was needed. Trans tunnel had to be massaged abit. Your diff will die a very painful death quite fast. Go hilux diff....
    Best part of it all is easy power, plenty of room up front, and the noise...... worst part? getting less than 200km per tank with granny driving.
    cheers.
    Quote Originally Posted by 4SFED
    is your 13B mounted from the 13B mounts or have you done the 12A trick?
    i measured the distance from the firewall to the engine mounts on a SIV RX7 and then likewise on a KE70 and the distances were within 10mm.
    ill have to investigate but i do see the 12A timing cover being a lot easier.
    Go drifting...
    Quote Originally Posted by andylaurel
    wish me luck
    woot! go for gold
    Junior Member Backyard Mechanic SIKTOY's Avatar
    You will need a 12A/early13B timing cover and a sump from a rx4 13B engine the 13B turbo mounting is no good for the conversion
    I will go through my photos and see if I can find some conversion pics from when I was working at pro rotor we did a corolla and a couple of celicas
    You will find that you can only put a N/A engine in it legaly in nsw unles you plan on putting a 10A turbo in it
    reputation is nothing knowledge is everything
    RA23 1GGTE 12.3@110mph
    1980 RA40 now getting a 1G with new picsLOOK
    Don't argue with an IDIOT.He will bring you down to his level and then beat you with experience!
    10a turbo..... rare as...
  1. MA70 --> JZA70 Conversion
  2. How to remove Corolla engine ?
    By corolla16 in forum Tech and Conversions
    Last Post: 27-06-2006, 01:49 AM
