Results 1 to 15 of 19
Thread: Making adjustable panhard rod.
    Default Making adjustable panhard rod.
    So I want to make my panhard rod adjustable. The way I see it is that I will need a sleeve (same diameter as the rod), 2 bolts (to be welded to the cut panhard rod) & 2 locking nuts.
    Would I be correct in saying the sleeve will have to be left hand thread at one end?
    Anyone done this, know where to get some cheap parts to put one together?
    Thanks
    Chris
    QUICKEST 1JZ'S IN OZ
    no backyard Domestic Engineer japlish's Avatar
    Default Re: Making adjustable panhard rod.
    i'm going to do this soon for my wife's ke70,
    i've got two rose joint rod ends and i've also bought a length of 25.4 mm 6061 grade aluminium.....that's as far as i've got
    cost so far - $50
    Destroyer of 'Drop Forged' spanners
    Jan 2007
    Do you really want to get rid of your wife that bad ?
    Aluminium panhard ???????
    Quote Originally Posted by rms
    do you actully know anything about metal strengths?
    Jan 2007
    I could ask if you are familiar with Rankine's and Euler's formula for stress in slender columns as well as fatigue limits for 6061 Aluminium ??
    oh now you become a smartypants
    how about you SHOW me why its bad to use alloy?
    oh look what i found
    mmm shiney ALUMINIUM
    and yes i have used both of these on my car in the past for over a year and never had issue's.
    Junior Member Grease Monkey DoctorDubb's Avatar
    May 2006
    Originally when i was thinking of doing this, i was thinking the other way around. I.e. the nuts welded to the original panhard and then bolts to the new 'sleeve'. Like this:
    http://www.toymods.net/forums/showth...ght=roadrunner
    Even better if you could actually get the threaded sleeve in the link above from somewhere you would then only have to:
    1. Cut panhard
    2. Weld nut on each end.
    3. ??
    4. Profit
    Thinking about it, its probably half a dozen in one and 6 in the other. Just posing ideas, i mean Roadrunner probably builds them that way for a reason.
    EDIT: Yes regarding your question, both the bolt and nut will have to have an opposite thread (left) to the other side (right). Otherwise you would be undowing one and doing the other one up and would get you no where
    1977 RA28 with 1GGTE - Now Driveable! Just with speed holes and no doors
    the hybrid Backyard Mechanic Fish's Avatar
    western australia
    why not just use 4130? or 1020?
    those parts look okay
    western australia
    yes you will need a LHT and a RHT.
    revolution racegear should have weld in inserts that would do the job.
    Ive use a lot of rose/hemi joints before. They dont last on the road, especially those cheap ones. If you want them to have half a chance you need to buy the teflon lined GREASEABLE ones (that is, ones with grease nipples).
    Quote Originally Posted by Screamn_Sleeka
    thats what i got
    Jan 2007
    Quote Originally Posted by japlish
    No ... not a smartypants.
    You asked the question if I new anything about metal strengths.... yes... it has been a part of my working life for over 40 years and I still learn something every day.
    Like the ad on TV ......'guess I'm not young enough to know all the answers'
    lol, sorry mate its just sometimes people come on here pretending like they know everything and are total knob's. i guess your not
    anyway back on topic
    Quote Originally Posted by Fish
    Awesome!
    If they do, itll solve a heap of my problems.
    Im going through all this at the moment building an adj panhard rods and upper trailing arms.
    I was going to do it using 1/2" nominal bore heavy pipe with nuts welded on the ends to take 5/8ths UNF threaded bar & rod ends to adjust the length, but my engineer says this is bad.
    He has seen 5/8ths threaded bar bend/break on panhard rods before
    So im trying to work out other options.
    cost so far - $50
    Hrmmmm... i paid $66 each for my 5/8ths spherical rod ends (heim joints, rose joint, or whatever you want to call em).
    Apparently all the cheaper ones are not rated for shock loadings like those seen in cars.
    The aircraft grade rod ends as used by V8 supercar teams, etc were >$120 ea.
  1. st141/rt142 adjustable panhard rod
    Last Post: 24-02-2008, 04:01 PM
  2. Panhard rod compatability
    Last Post: 24-05-2007, 08:03 PM
  3. adjustable panhard rods and roll centers
    By Celica RA45 in forum Tech and Conversions
    Last Post: 29-04-2006, 03:20 AM
