Page 1 of 4 123 ... LastLast
Results 1 to 15 of 48
Thread: Alternative to sand blasting (rims) ???
    West Australia
    Default Alternative to sand blasting (rims) ???
    Hey guys,
    Got some centres (4) of 3 piece rims that the paint is pretty shitty on, and ive got several quotes for sandblasting , All ~$80 EACH CENTRE to get done... that does NOT include powdercoating ...
    is there any "DIY" way of getting baked on paint of wheel centres that would cost less than $320 ???
    If i was able to remove the shit paint myself at home , i could paint over them with some hardcore engine enamel or something similar that can stand harsh conditions and heat...
    All help much appriciated and +repping will be done !
    <3
    John.
    Default Re: Alternative to sand blasting (rims) ???
    Do you know of someone who has a strip tank with Turko? Leaving rims in Turko for 24hrs does plenty.
    Oh - and as for paint - There are a few products on the market. I like using a baked enamel where possible - you need the paint, the correct thinners and primer + an oven that the rims can fit in. - Sorry edit again - Wattyl sell the things that you need.
    West Australia
    Thanks yellorolla but :
    If i was able to remove the shit paint myself at home.
    Sorry old chap - you can buy a cheap blasting gun from Supershit - then you need a compressor and some sand and Bob's your uncle.
    Then you need to spend the next week sweeping up the sand...
    Send me the centres. I'll get it done for you cheaply.
    Quote Originally Posted by shelldrake
    And he could probably arrange to have them powder coated cheaply (ie. at a good price, not cheaply done) also...
    ([][][]II--LT--II[][][])
    West Australia
    would cost about the same to send them there , get them back , sandblasted and powdercoated as it would cost to just take them to my local industrial area to get done ...
    Thanks for the offer shelldrake, but i need ideas on how to DIY at home....
    West Australia
    What about mixing Paint thinners and a slight bit of Hydrochloric acid and water ?
    Scrub with a metal brush ?!
    Make a good stripper for baked on paint eh ???
    Paint them with brake fluid for a few weeks (each day)?
    btw find a better powder coater ffs. I got two motorbike rims blasted AND painted for like $100
    West Australia
    LOL , i rang all sandblasters/powdercoaters in My area, tehy all said around ~80 bux per centre
    I think you'd probably still get it done cheaper than your quote for sandblasting alone...
    Coffee - in the past when stripping paint I have favored teh use of automotive type paint stripper, the remove with the thinners and a scotch brite. One needs good gloves for this approach.
    If the job doesn't go too well, just sniff the thinners and things will appear much better.
    West Australia
    but does this automotive paint stripper , remove baked on paint which is used on WORK/RAYS rims ???
    the paint is on there pretty hardcore..
    Is there a chemical that u could just soak them in to remove the paint evenly ...
    Take them down to the closest park that has a sand pit and roll them around until paint is removed.
    If they arn't alloy could you get them acid dipped?
    What about just sanding down any loose faky bits and just painting over them?
