Hi Anthony, sounds interesting!
Depending on what your planning to spend, but going on the conversion i don't think this will be an issue.
The best option for you is a dual pickup type, these use two (some times more) magnets, One typically on the tail shaft and another on an undriven wheel, this is where they sometimes use 3 pickups one for each front wheel (for hard cornering).
Reason for using dual or more pickups is so that you get as close as possible "actual" car speed when out on the track etc.
If your just using this car for a daily then by all means, any normal single magnet pickup on the tail shaft will do the job! Do some wheel spins and get that needle off the clock
They are sold as kits, usually available from big companies that deal in gauges. I think Dakota Digital do one. Other wise it's not hard to buy the parts and make one up. Just have to make sure the pickup - brains - gauge will work together. Don't think you'll have any problems as a lot of people use them for after market ECUs either for Track Work where accurate car speed is desired or for launch/traction control!
