I simply use the PPG Galvaplast microfine, because it works in all situations, mega filling without bubbles, and great for the fiddly bits. Not cheap, but does a great job. If you are reforming a major part of a guard for instance with "bog" I would suggest using a fibreglass reinforced bog, or do it properly with a welder and some new metal. All panels should be straightened out as best as possible using hammer and dolly, or shrinking hammers and oxy heat. Bog should only be used for filling smaller imperfections, anything deeper than 5mm and you risk the bog falling out. I owned a KE10 way back that had a bonnet repair using half a kilo of bog. Much amusement to the troops as the bog jumped out as we drove across a set of railway tracks!
Your normal bog available at auto stores will generally form a heap of bubbles when mixed, and is made of coarser materials, so not as suitable for filling the smaller pock marks etc.
Hi fill is limited to a thickness of about 1.5mm before sanding, and you would aim for less than 0.5mm when sanded.
cheers Chuck.
