check this article originally posted by Mos
http://www.colder.com/Downloads/NPT.pdf
also lots of info on wikipedia search wiki for national pipe thread
Hey all,
Did a quick search but the terms are too short to search for properly.
Just wondering the difference between NPT and PT sized threads? I currently have 2 temp and 1 pressure sensor all in 1/8 PT but every adapter ive looked at has 1/8 NPT sized holes. Does anyone know where adapters can be purchased with 1/8 PT thread sizing? Cheers.
Eddie.
4agte finally completed. 234rwkw @ 8125rpm. Tis fun
i thought that the threads were 1/8" BSP......Originally Posted by Big T
You could try your local hydrolic's shop, eg. Enzed, or Pirtec....
They should have an adaptor...
Q:- what motor they is on..??
I found that the toyota oil pressure was 1/8" BSP...
NPT is an American thread size...
Project: '82, GA61 XX
I've found that is true on my old 4AGE - the oil pressure sender thread was 1/8 BSP, so i got a BSP-NPT adaptor from Motorsport connections, seven hills.Originally Posted by GA61XX
On my 18R-G though, i can get a 1/8 NPT thread sender into the oil filter mount - so i dunno if all toyota engines have 1/8 BSP threads?
Cheers guys.
I finally figured out what the standard PT means... its actually the Japanese Industrial Standard for threads. I found an awesome PDF that shows thread interchangeability:
http://www.pneumation.ca/website_pdf...pipethread.pdf
JIS standards are basically the same as BSP which explains why all BSP threads will fit into our Jap made engines
Eddie.
I can confirm this.I've found that is true on my old 4AGE - the oil pressure sender thread was 1/8 BSP
http://www.toymods.net/forums/showthread.php?t=20467
BSP =British pipe thread?
NPT = National pipe thread?
One CAN (not ideal but still works) can be used in one but it wont work the other way round.
E.G. NPT wll go into BSP but BSP wont go into NPT. Or maybe its the other way around.
Never heard of JIS heard of JIC just not JIS. Whats JIS?
Oh, cheers for the chart BIG T thats awesome mate. Thanks!
JIS is written on many alloy wheels
(\__/)
(")_(")
Arr ok cheers steve, what does it represent on a wheel tho?
JIS is the Japanese standard (Japanese Industrial Standard)
JIS pipe thread = BSP
http://www.engineeringtoolbox.com/th...rds-d_776.htmlOriginally Posted by website
I have found BSP and NPT to be interchangeable in practice at 1/8 and 1/4 sizes.
NPT is national pipe taper
BSP is British std pipe. Usually you have a BSPT OR BSPP taper or parallel designation.
../delete/ban
tech moderator
when i tried to put an NPT threaded sender into the BSP threaded socket on my 4A-GE, it didnt go. I felt thread interference and so went and double checked with a fittings specialist who suggested i try the adaptor.
BSP-NPT adaptor = win.
If you are referring to an alloy wheel specifically one made in japan, the little logo present on them that says JIL or something like that is a stamp to say theyve passed tests aimed at testing theyre strength.Originally Posted by jeffro ra28
On a side note, american wheels are generally stronger than japanese ones as the tests put more force on the wheels than the japenese tests. In both tests though they put weight on the wheel and drop it at an angle at a predetermined height. Pretty sure this is because generally american cars are heavier than japanese ones.
JIS = Jap Industrial StdOriginally Posted by jeffro ra28
JIC = Joint Industries Council, a group that got together to "standardise" these things, and are probably still working on it. JIC is most commonly described for the 37.5 degree taper you see on the speedflow/earls/etc fittings.
Friends
