Results 1 to 6 of 6
Thread: 4AGZE AW11 MT Flywheel bolt torque
    When ASIO calls I'm a Backyard Mechanic McFly 11's Avatar
    Q
    Default 4AGZE AW11 MT Flywheel bolt torque
    Gotta love Toymods Tech forums - I have detailed instructions on the best way to install a flywheel, courtesy of Billzilla Now I just need the actual torque settings for the flywheel bolts and I'm ready to roll with the rest of my Auto > manual conversion!
    http://shell.deru.com/~sgn1/AW11/4agetrd.htm lists formula atlantic torque specs @ 85 ft/lb (= but I remember NA 4AGs being around 54 ft/lb? Anyone know for sure what the setting should be for a supercharged MT AW11 MR2?
    Junior Member Carport Converter 4agte's Avatar
    Default Re: 4AGZE AW11 MT Flywheel bolt torque
    i cant remember off the top of my head but make sure you have BRAND NEW flywheel bolts
    if you are still stuck tomorrow ill dig up my bgb
    Q
    Cheers 4agte, but I already have the BGB and it actually doesn't cover flywheel removal at all ): That said, it does list generic torque settings which amount to:
    55 Ft/lb for the basic (unstamped) bolts
    and 63 Ft/lb for 5T 14mm bolts.
    and 108 Ft/lb for 7T 14mm bolts!!!
    I had to get new bolts anyway because the MT ones are longer than the AT ones and I WASNT going to stooge on such an important part of the job (= The bolts don't appear to be rated though I expect they are high tensile but not stamped because they are a purpose-built part?
    i think you have to half torque them too
    Quote Originally Posted by McFly 11
    Giday Check EM100 of the BGB for flywheel install method, and torque rating of 74Nm.
    Q
    So it does, I stand corrected! I thought I looked though it thoroughly too - guess that's why its called the BIG green book :0)
    Now its officially on the tech forums too... rep all round (:
  1. who knows about stretch bolts??
    By 1jzracing in forum Tech and Conversions
    Last Post: 08-10-2006, 09:01 PM
  2. Article: Torque / Work / Power
    Last Post: 02-06-2006, 02:03 PM
  3. st162 bolt torque specs
    By Bahnugget in forum Tech and Conversions
    Last Post: 30-01-2006, 10:53 AM
  4. flywheel bolt torque
    By ae86 slide in forum Tech and Conversions
    Last Post: 30-12-2005, 10:05 AM
  5. 4AGZE 212mm vs 200mm flywheel
    By craigy in forum Tech and Conversions
    Last Post: 22-12-2005, 10:55 AM
