Results 1 to 12 of 12
Thread: Oil smoke- confirm my suspicions + what bb turbo to swap in?
    Junior Member Backyard Mechanic ONCE-NA's Avatar
    Default Oil smoke- confirm my suspicions + what bb turbo to swap in?
    Okay, finally got the bitch 3S back together again and running, with new head etc. Now it seem to run alright and not smokey when driving as far as I can tell. But if you leave it over night. then warm it up in the morning it starts smoking out the exhaust. Not on start-up like a valve stem seal problem, (its got new seals anyways) but when it gets quite warm. After a bit of a drive it clears out and is fine. And doesn't smoke when idling / warming down. Only when you go back to it after an extended off period. So, I think its the turbo shaft seal weeping a bit of oil post shut off, (Probably does it while driveing too but you don't notice as it has no time to build up).
    What do you guys think?
    Default Re: Oil smoke- confirm my suspicions
    Definately sounds like its the turbo.
    Jun 2007
    2nd confirmation, here, that its the Turbo oil seals.
    Also good excuse for an upgrade.
    Yeah! So I need to find a BB watercooled unit with similar specs to the Garrett T4 A/R .60 compressor and .58 turbine. At least the T4 to manifold bolt pattern, I expect to have to make a new dump pipe.
    Default Re: Oil smoke- confirm my suspicions + what bb turbo to swap in?
    I'm thinking the GT30R or 35R the bolt spacing doesn't match.- 70mm x 86mm what i've got (approx) vs 44.5mm x 86mm. but should be enough room on the manifold flange to modify. What do you rekon?
    2JEJ Grease Monkey petespipes's Avatar
    if you weld that gt 30\35 [t3] flange onto your manifold you are free to fit the turbo of your choice.
    gt 30 variety turbos cost 1800 new and sell at 1000 s\hand.
    then there is your self destruct ebay turbo at $650 new.
    selling the car next week? in no particular need of long term friends? china is your
    [email protected]
    its ok not to know everything
    cat-converter maybe?
    (go the new turbo anyway )
    Forum Sponsor Conversion King
    GT3076r with a .63 turbine housing on it would be my pick, just weld a t3 flange on your existing mani and diegrind it so there is no step, may need to fill the inside with weld abit to get a nice taper but can be done.
    would be an extremely quick street car with that turbo.
    linden
    What could be wrong with the cat that would cause smoking? It was new just before the 3S went in but has since has bulk amounts of oil pass through it so it is probably fucked. But would it couse those symptoms?
    maybe once or twice if it was just residual build up but not each and every time you start it, id drop the dump off and see if its oily first and also check how your breather setup is working.
    maybe alot of pressure in the crankcase is forcing oil thru the rear or front seal of the turbo, alternatively what sort of PCV setup do you have?
    linden
    Just running a hose from the main (gen 2) vent off the cam cover into a catch can and then from the can through a 1 way valve back to the turbo intake. Doesnt push any oil out of there. Yeah I'll take the dump off again and have a look maybe run it it without the dump till warm and then the next day again to see if it exhibits similar symtoms
    the hose size goes down to about 3/8" on the intake. The 3S doesn't normally have a breather on the block at all does it?
  1. 1JZ Has Smoke After Back-Off
    By jak in forum Tech and Conversions
    Last Post: 20-09-2007, 08:25 PM
  2. 4agte blowing lots smoke and missing
    By Necros in forum Tech and Conversions
    Last Post: 28-02-2007, 08:42 AM
  3. Engine Smoke diagnosis required
    By skelz in forum Tech and Conversions
    Last Post: 11-07-2006, 11:26 PM
  4. st162 spewing white smoke on startup
    By pr*duct in forum Tech and Conversions
    Last Post: 24-05-2006, 11:37 PM
  5. blowing smoke on boost, 1ggte, clean motor!
    Last Post: 05-05-2006, 04:58 PM
