so you used one of those ball and spring controllers or just a bleed controller?
its looks like a bleed controller because you have tee'ed the output of the controller with the wastegate and the prespool valve (2nd turbo 'wastegate' or "Exhaust Bypass Valve") is this right?
i have beenn thinking about this but would rather a ball and spring valve on the wastegate and a bleed valve on the pre-spool (its the prespool opening that acts as a second wastegate for the first turbo BEFORE the second turbo come online which is responsible for limiting the boost on first turbo.)
so this would effectivly add 'lag' to the prespool valve (bleeding off pressure to the actuator to make it open later like a wastegate) to increse boost for the first turbo,
how dooes this affect the point at which the solenoids open to engage the second turbo in sequential mode, does it still feel right?
i dont know if the solenoids open according to revs or a pressure signal, but i thought the EBV was an important part of the process of transferring gas to the second turbo.
if the EBV is opening later in sequence and the ICV and ECV are still opening at the same time then the second turbo is going to be spinning slower than designed when it gets full gas pressure.
higher boost on the first turbo would certainly make up for this but the shock load to the second turbo and risk of compressor stall would be greater if the ECV opens before the EBV or before the EBV is fully open.
this is a really good experiment that i had planned for my 2jz before messing aaroudn with the sequential system, i would be really interested to know how it goes.
