Results 1 to 15 of 28
Thread: Limits of a 1GGTE
    Powered By Żywiec Backyard Mechanic Adash=P's Avatar
    South Austrlia
    Default Limits of a 1GGTE
    Just wondering if anyone knows how much power the 1G can make with stock internals.
    Thanks
    AE93 SX - Thrasher 20V
    JZX100 Chaser - Daily 1J lovin
    Default Re: Limits of a 1GGTE
    There's one guy in melbourne who claims 600hp with std internals....
    Just like everything with that particular clown, I'd say he's lying.
    more like 350hp.
    Facebook | LinkedIn
    I know 250rwkw is achieveable,
    And I have heard of over 300rwkw though I'm yet to see the results myself (that was on a stock bottom end, modified head.)
    Beige.... The new Black!!!
    Quote Originally Posted by Lambolica
    *nods*
    Mine will be putting out 250rwkw at the moment on a stock everything.
    300 I've also heard of, but I dare say as said above, the guy was talking through his sphincter..
    Facebook | LinkedIn
    emp-2tg's car put down 300rwkw before it had a sad. Nothing spectacular though, and his was an old Gen1 so it was more like the damn thing just wore out.
    I know of a 346rwkw but I am unsure of weather this was running stock pistons or forgies. It was running a factory bottom end. and that was with an auto.
    Edit: it still had TVIS in it... modified but still there.
    when you start pushing more than 20psi with a decent turbo they should last around 12months if its a healthy motor, im guessing the weakest link is the pistons, as thats how both my motors died... neither was spectacular just started smoking abit and using oil...
    im now rebuilding one with some good pistons and afew other parts like cams and what not
    im hoping for around 350rwkw if i lean on it, but time will tell hey
    ok im saying on stock internals, safe power would be around 250rwkw on about 20psi
    KE38 - 2TG
    MS65 - 1UZ
    Junior Member Automotive Encyclopaedia Nim's Avatar
    What kinda mods do you guys do to push that much power?
    Daily: DC2 Integra VTiR :: 96kw @7300rpm - 132nm @6300rpm
    Techno Toymods | Beninca Dyno Day Results 10/9/05 | GOR Cruise '06 | My Photography and Illustration
    boost + fuel = power
    its as simple as that with mine, im still using the stardard exhaust manifold and standard plenum runners, stock head, stock bottom end 440cc injectors, stock fuel reg and a cheap hybrid copy intercooler and microleb ltx12s
    KE38 - 2TG
    MS65 - 1UZ
    South Austrlia
    Cool. I've seen one 1G in a Gemini make over 300 at the wheels but thats been worked.
    stock internals you can make 300rwkw
    but it wont last long
    KE38 - 2TG
    MS65 - 1UZ
    emp: That is pretty amazing what your last setup made. When it made the 280rwkw was that tuned or untuned? Don't suppose you want to show us your ignition map?
    QUICKEST 1JZ'S IN OZ
    Im picking up a 1g real soon, and i was jus making up figures in my head. but i was wondering how much boost will the standard turbos make before they are gonna give up. im talking like a reliable boost level but. one i can sorta run for a long time before they give out...
    cause the lack of money, im gonna run a starndard ecu and loom, standard turbos. fuel system, cooler and exhaust. wat power u reacon is obtainable wif this?
    ahaha, im being a wanker with this post, but im curious to know...
    thanks,
    jason
    JZA023
    Around the 140-150rwkw mark is fairly standard for the factory ECU/turbos combo on a Gen3 1GGTE, with an exhaust and roughly 15psi.
    and the longevity of the turbos will greatly depend on prior maintenance of the engine e.g. my old turbos died at 11psi whereas other people run 15psi all day for ages.
  1. 1GGTE into RA65 Questions.
    By Ashe in forum Tech and Conversions
    Last Post: 20-11-2006, 08:51 PM
  2. 1GGTE 12 pound boost problem ? i need some help !
    Last Post: 29-12-2005, 09:12 PM
  3. 1ggte on gas
    Last Post: 27-11-2005, 12:32 PM
