6-7.5" means that ideal is more like 6.75".. so a rim 1.25" greater than recommended, and 0.5" greater than the max is not a good recipe...
if you have 14x7 or 15x7 rims, then you wouldn7t have such clearance issues and the tyre would fit even better
the reason it is done, is to have fooly sik dish.
if you have clearance problems because your rims are too wide... well... the obvious answer is that your rims are too wide
it also depends if you just want to drive slowly, or if you will drive the car normally. but the sizes you are suggesting may not be so much fo a problem...
will your insurance be voided in the US for having illegal wheel/tyre combinations?
