Results 1 to 12 of 12
Thread: maximum tyre width 18 X 8 rims
    Default maximum tyre width 18 X 8 rims
    My car runs stock 205/55/16 tyres.
    I am getting new 18 X 8 rims.
    The tyre shop has quoted using:
    Front 235/40/18
    Rear 265/35/18
    The rear tyres fall outside the rim width to tyre size guide.
    Is this going to be ok or will it handle like a pig?
    Should I be using smaller rear tyre?
    Default Re: maximum tyre width 18 X 8 rims
    Front 235/40/18 , Sure, these will fit no problems, im running these sizes...
    Rear 265/35/18 , Doubt they will fit on 8 inch wide rims... I have these sizes on 18x9 rims and would can only go 275's max on a 9 inch wide rim. SO i would say get some 9 inch wide back rims and go the 265's.
    11.72 @ 116.7mph = Quickest Stock Turbo Jzz30 series Soarer And 1st into the 11's WOOOT!!!
    Still going good
    265/35/18 do fit on a 18 x 8 rims, I had a quick search and 350Z and LS1 guys seem to use these. I will try asking them I think.
    I would go 9 inch in the rear if I could buy them in that size.
    I have run 255 on a 8 inch rim and they had no sidewall bulge at all in a 35 profile. 265 isn't optimum but will be fine.
    Forum Sponsor Conversion King
    Quote Originally Posted by broken22
    Front 235/40/18
    Rear 265/35/18
    what brand of tyre?
    i have a 265/30x19 falken on 1 of the rims i bought and they sit perfectly but there is a 265/30x19 ventus on the other rear rim and its bagged like a mofo,
    both rims are 19x8.5 so obviously diffent brands must use different ways to measure there tires (falkens allways seem to be narrow)
    IMHO i would just run the 235/40x18s all round provided the wheel offsets are the same and that way you can rotate wheels without any probs.
    linden
    thanks for the replies. Forgot to mention front and rear offset will be different, so tyre rotation isn't a concern. Tyres quoted are Nankang NS2.
    Forum Contributor Domestic Engineer
    I run those exact sizes for rims / tyres in a toyo T1R.
    The rears seem to have a bit of angle about the sidewall, but it doesn't seem to be too much of a problem. That said, there are other points in my suspension setup that would show before the sidewalls.
    I have no trouble with uneven tread wear etc.
    Can someone link me to the rim width to maximum tyre size guide?
    I have a copy of the rim width to minimum tyre size guide, but it doesn't mention the widest tyre to fit on x rim.
    New Zealand
    http://www.goodyeartires.com/goodyea...ector/size.jsp
    I use this one, probably brand/type specific but will still give you a good guide. Gives recommended rim width once you select a specific tyre.
    Callum
    Turns out 265/35/18 won't fit that easily on my car.
    I ended up with:
    Front: 225/40/18 (any wider they hit the strut)
    Rear: 245/40/18 (265s would require flaring)
    Junior Member 1st year Apprentice rona wagon's Avatar
    vic
    i hope you didnt go the nanas again. cheep nasty things spend the coin and get somthing good. (good year, dunlop, b/stone)
    Rub some dirt on it
  1. St185 gt4 - rims - 17 inch - what profile tyre
    By Classique71 in forum Tech and Conversions
    Last Post: 07-02-2006, 08:06 PM
  2. Tire Size Guide
    By newbien in forum Tech and Conversions
    Last Post: 12-01-2006, 12:58 PM
