Results 1 to 8 of 8
Thread: Hemispherical heads: 2T, 3T, 22R, 3M, Vseries
    Not known unless ur blown Backyard Mechanic
    May 2007
    Default Hemispherical heads: 2T, 3T, 22R, 3M, Vseries
    Basic run down -
    - "With the hemispherical combustion chamber design, the intake and exhaust valves are usually on opposite sides of the chamber, unlike the in-line valve arrangement common to most engines with wedge-shaped combustion chambers." - Wiki
    - "With a hemispherical chamber, larger valves are possible and a straighter, less restrictive flow path can be provided for the air/fuel mixture." - Wiki
    Hemispherical combustion chamber:
    In a HEMI engine, the surface area is much smaller than in a flat head, so less heat escapes and peak pressure can be higher.
    It's known for reducing knocking with being more forgiving of octane levels.
    I don't know enough about it all, but in a perfect world where we didn't have to worry about emissions, shouldn't these motors be able to go harder than other motors once forced induction is applied due to the thermal efficiency and flow?
    Very cool side note, in 1940 Chrysler produced a inverted v16 that produced over 3000+hp
    In the P-47 at 15,000 feet it pushed the aircraft at 504mph.. The important thing to keep in mind about this engine is that it was a Hemi headed, push rod valve activated type.
    Default Re: Hemispherical heads: 2T, 3T, 22R, 3M, Vseries
    Well no, hemi chambers are crappy compared to a decent one that has squish areas. There's no reason why you'd want to use one over a good design if you have the choice.
    www.billzilla.org
    Toymods founding member #3
    It's very difficult to get a decent compression ratio out of a hemi. You can use massively domed pistons but that causes other problems. Definitely not suitable for modern engines where the trend is for higher CR, even in turbocharged engines.
    Junior Member Domestic Engineer MRMOPARMAN's Avatar
    vic
    Quote Originally Posted by Radar
    in the old days before decent head design, hemi heads were the shit, especially when supercharging, look at drag racing history, a hemi or hemi derived engine absolutely killed american drag racing (cant remember the class, top fuel or pro stock maybe) every year except 1966, when a ford sohc won.
    like bill and norbie said, head design has changed to the point where TRUE hemi heads are outdated, produce shitful emissions and are less powerful. this increases bigtime when naturally aspirated as norbie bout needing domed pistons to get decent comp out of them..
    dont believe everything you read.. new chrysler Hemi's arent true hemi's.. even the old chrysler Hemi 6 wasnt a true Hemi.
    hemi heads were originally developed for planes, and the idea had been around quite a few years before chrysler get their hands on the design.
    well have to see what gen is better the ke30 or the ke(yuk)25
    Thats like comparing a house brick and a stiletto
    Junior Member Backyard Mechanic Hash_ra23's Avatar
    isnt another reason that ur limited to two valves per cylinder?
    1977 RA23 Celica -> 1ggte conversion [SOLD]
    MA70 Supra 1JZ 5speed [SOLD]
    Current: IS200 1JZ VVTI 6 speed
    May 2007
    So whats the best cyl head for power in the 2.0L category?
    vic
    3sge beams, cosworth are pretty good, f20c honda head.. theres heaps of heads out there that are substansially better than ye olde 18rg/3tgte heads
    May 2007
    I guess your all right, after all it is over 30yrs old =] How about a diesel 1.8L to 2.4L with a decent flowing head.. any of them?
  1. TG engine info!
    By MitchE in forum Tech and Conversions
    Last Post: 30-07-2010, 07:27 PM
  2. 1972 celica ta22 1972 does it have a 3t or 2t engine need help
    By HAIRY_APES_22'S in forum Tech and Conversions
    Last Post: 06-08-2007, 10:18 AM
  3. 2tgue & 3tgtue info
    By chippa07 in forum Tech and Conversions
    Last Post: 06-01-2007, 08:29 PM
  4. 2T Head and 3T Block, standard items - any problems?
    By -NiCkeL- in forum Tech and Conversions
    Last Post: 09-11-2006, 02:29 PM
