Results 1 to 15 of 30
Thread: W50-18RG rattle
    Default W50-18RG rattle
    Well at the end of my Wakefield Day i noticed a tappy rattly type nosie coming from what seemed the engine bay.
    Checked oil ...low. Ok probly lifters... oiled it up .. still noisy.
    Noticed gears slightly harder to engage. Thought gbox / clutch issues. Suspected the clutch was always a bit average.
    Take to clutch place Monday Arvo .... guy said if the clutch being pressed doesnt change the noise then its not clutch / gbox. He listened and said definately motor ... possible piston ring land and / or chipped valve if he had to take a guess.
    Called mechanic mate in ... Compression test.. 130-130-120-90. Squirt of oil into chamber..compression jumps up to normal.
    What is this likely to be (the compression issue) ?
    Mate said cant tell until motor is pulled down.
    Get to work this morning, idling in car park space... notice the sound at idle. Press clutch in.... no noise. So going by the old fella at the clutch place would one assume this rattle is a clutch / gbox issue?
    Noise really is onlyaudible at about 2500-3000rpm in any gear. Gets louder and faster with increasing revs. Back off slightly on the gas and the noise stops until the revs drop to where you backed off too.
    Now mate thinks thrust / spigot bearing?
    Any opinions before i pull things apart... just need to know what im looking for / at?
    Nathan
    (Sorry for the length but needed all the info out there )
    Default Re: W50-18RG rattle
    If the noise goes away when you push the clutch in, it's definitely not the thrust or spigot bearing. They are spinning when the clutch is in and idle when the clutch is out.
    Nope, sounds more like you've got dud bearings in your W50. I'd advise you to check the oil level, you might find the rear seal let go at Wakefield and spat all the oil out. A similar thing happened to my W50 a few years ago and it started rattling badly until it died completely not long after.
    will do. as long as it turns out to be the box and not the motor ill be happy. easier to change and cheaper.
    not at a point where i can afford to open the ol 18rg up right now.
    Thanks norbie
    I know it sounds silly, but timing chain?
    Facebook | LinkedIn
    Chain rattle will usually manifest itself at idle or low rpms when the oil pump is not providing enough pressure to push the chain tensioners out fully.
    cheers,
    Charles.
    Was just a thought..
    my 18rc would rattle all the time..
    But, it wasn't long till it rattled it's way THROUGH the timing case.
    Facebook | LinkedIn
    Melbourne Victoria
    just watch the oil pressure ,it might have spun a big end .18rg in std form dont like going around race tracks ,most of the problem is the sump design having oil in the centre is not really good as under braking the oil shifts to the front and under aceleration the oil ponds to the back and you end up sucking air in
    dont forget those long sweeping right handers!!
    my gearbox si doing the same thing, make a hell of a racket in 2nd too
    The boobs are back
    Quote Originally Posted by TA-022
    well it definantly aint lifters in an 18rg...
    Same thing happend to my t50. Sounds like you need new bearings or are up for a replacment box.
    timing chain tensioner was replaced 1 month ago (leaking) and chain tension checked by stewart wilkins rallying so I trust that is in order.
    pretty sure its clutch / gbox related now.
    checked oil today and replaced.... no change ... mate recons thrust bearing or dead/dying box...
    gunna further inspect this weekend.
    thanks heaps guys!
    south australia
    but why the low preasure in one combustion chamber?
    maybe not related to the noise but still a noticeable difference to the other 3?
    always suspected a valve seat or something. No oil in water and vice versa but allways ran a little rough / lumpy on idle.
    I have the same problem with the T50 in my Three Tone Green TA-22 and also developed at Wakefield.
    Rattle sound is there when in neutral and goes away when clutch is dis-engaged.
    This is the sound most input shaft bearings make when on their way out. I have done two boxes in the past in my race car with exactly the same symptoms.
    Regards
    Rodger
    Does sound like a noisy bearing... open up the box i say.
    With your compression issues, it wont be a leaky valve, because when you did the oil test, the compression went back to normal, so its definitely ring related. I would say you have a badly worn ring (if its number 4 that is low) because number 4 always has the greatest amount of strain on it, as it is closest to the load (sounds a bit wierd in some ways, but its true), and number 3 has the next greatest amount of strain, hence no. 3 being low, but not as low as 4. Personally I would say replace either the bearings or the box, and rebuild the RG.
  1. 18RG into SA63
    By sa63-18RG in forum Tech and Conversions
    Last Post: 05-02-2006, 07:09 PM
  2. Computer Engine Modelling, (18rg in particular)
    By jeffro ra28 in forum Tech and Conversions
    Last Post: 08-01-2006, 11:20 PM
  3. W50 into RT81
    By gianttomato in forum Tech and Conversions
    Last Post: 17-12-2005, 01:29 PM
